Question about O2 Xda IIs Pocket PC
Backlit the backlit light doesnt function so i have a hard time working wit the PDA.so working at night-no.no. help.earlier the touch screen broke so i had 2 replace a new 1.
  • Anonymous Dec 05, 2007
    hi there, my xda IIs rocks, well did...you see it has had a few knocks and falls, but recently it had 1 fall that killed the phone ish, the backlight always flickers and every minute goes fuzzy for around 10 seconds, but then is back ot normal again, and when taken from its cradle the problem get even worse!! any way i can fix it? also the sound is just zzzzzzzz, but i really dont want to get a new one!! any ideas?
    Sergeant:
  • 452 Answers
Go to start>settings>system>power>check the backlit light function to be set to ON. otherwise have to visit auth service center for backlit light checkup.
Posted on Oct 22, 2007
6ya staff
SOURCE:
Phone not backlit
The Mitel 4025 (and 4125) was originally available in two models, an earlier non-backlit model and a later/newer backlit model. There is no lighting available in the non-backlit model, so if that's what you have, you're out of luck.
Feb 04, 2014 | Mitel Superset 4025 Corded Phone...
Sharp comfort touch air conditioner screen doesnt show settings and buttons wont work after cleaning. help its hot!!!!!
Switch off the unit at the isolator or fuse box. Leave off for 10 mins to reset. When powering up again and it still wont work, check your remote control batteries are good. Also confirm you haven't "blanked out" the display. Some controls have a display or LED function which blanks out the display so that the lights are not bright at night time. (For bedrooms so that the light doesn't keep you awake) Also check that you have not pressed a "child lockout button" This will stop anything ..
Jul 25, 2013 | Heating & Cooling
Touchflo of HTC Touch 3G won't launch
Hi. TouchFlo is the special today plugin for the HTC devices, and as you realized, you can still use all functions of your PDA without. I think there is an error in the installation of TouchFlo (There can be a bunch of reasons, we have to know everything you did with your PDA in order to guess them), but there is a safe solution for that problem, you can backup all your personal data and software to your PC, then you can hard reset your PDA to its factory default settings. That way both your phone and the TouchFlo will work. In order to hard reset your PDA (after the backup of your personal data), you can follow the steps in this link: (http://www.hardreset.eu/htc_touch_diamond_hard_reset_soft_reset_en.html). Hope this helps.
May 27, 2009 | HTC Touch Diamond Smartphone
Touch screen problem
pls reset ur device like this if it doesnt help then u have to get ur digitizer replaced also called touch panel
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Apr 07, 2009 | HTC Touch P3450 Smartphone
Touch pro screen blank
first try this
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
if it doesnt help then then go to www.htc.com and upgrade ur ROM
Pls rate me FIXYA if it helps
Mar 14, 2009 | HTC Touch P3450 Smartphone
Stuck on windows boot up screen
Regarding with your HTC Viva / Elf
Try hard reset with phone in "OFF" state following this instructions if it will do;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button under the battery cover at the top
of the device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have
been backed up before a hard reset is performed.
3. Release the TALK and END buttons, and then press ENTER on your device.
Mar 03, 2009 | HTC Touch P3450 Smartphone
No power When I press power button.- Battery is full
Try changing ur battery if it doesnt help then do this
try pressing the reset button near the charging port on the pda if it doesnt work try to hard reset it as follows
try this if it helps
if not solved then go to www.htc.com for latest Rom update downlaod and update
other wise check xda forums for software dead HTC http://forum.xda-developers.com/
pls do rate me if i fixed ur problem
Feb 24, 2009 | HTC Touch P3450 Smartphone
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
Blackout Mode On and Off
When Blackout mode is turned on, the monitor display will turn off to
reduce power consumption.
This additional power enhances the sound quality.
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
function will be displayed for 5 seconds to show the operation before
returning to Blackout mode.
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Imate jasjam
I would look at some third party applications that clear up the memory while you are on the PDA / JAM. You can also go into the settings function, memory and view running programs.
One of the earlier version flaws of Windows 2003 is that it does not offer a shut down menu on the Today Screen. There are quite a few freeware applications that allow you to shut down running programs. I tend to run one or two programs - maximum at a time. This is not a laptop. I find my touch screen unresponsive if too much memory is in use. It's not really the touch screen but that the computer can't follow my commands, almost like an old 283 or 386 computer.
Take a look for these tool bar/memory manager programs before sending out to service in Mumbai.
Dec 11, 2007 | i-mate JAM Pocket PC
Cracked touchscreen
There is no need to replace the whloe lcdscreen, you just need to replace the touch screen & panel which is a thin glasstop on the top of the lcdscreen. The whole lcdscreen is expensive, while a touch panel is much cheaper than that. And we could provide all kinds of PDA accessories. Here are some information for you In general, PDA LCD screen comprises the touch screen. LCD screen acts as a display of PDA or SmartPhone, and the likes, which cannot go without LCD screen. Touch screen is short for touch screen digitizer which seizes the upper part of PDA LCD screen. It is pressure-tactile, runs with gentle touch of stylus, finger and other tele-pointing function-possessed device. Different from LCD screen, the touch screen is an optional component for PDA, SmartPhone, and the likes. A PDA can function well even without the assembling of a touch screen for the availability of keyboard.
Sep 09, 2007 | T-Mobile MDA
O2 Xda IIs Pocket PC Logo
44 people viewed this question
Top O2 Computers & Internet Experts
Ekse
xxxxxx xxx
Mufaddal  Kurlawala
Mufaddal Kurlawala
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
