Some shots look OK on the display but when uploaded onto a computer the left part of the image appears on the right side ad there appears to be an overlay.
You aren't being impatient and unhooking from the camera or card before it totally completes the transfer, are you?? That's the only thing I can think of, except for a loose connection. Make sure things are plugged in solid... then, be still... and don't be fooling with things until you're sure transfer is complete.
Testimonial: "No, the transfer is done by putting the SD card into the computer and downloading all pictures at once."
Checking replaceables
If you experience frequent paper jams or printing problems, check the
number of pages the machine has printed or scanned. Replace the
corresponding parts, if necessary.
1. Press Menu until System Setup appears on the bottom line of the
display and press OK.
2. Press the left/right arrow until Maintenance appears and press OK.
3. Press the left/right arrow until Supplies Life appears and press OK.
4. Press the left/right arrow until the item you want appears and press OK.
• Supplies Info: Prints the supply information page.
• Total: Displays the total number of pages printed.
• ADF Scan: Displays the number of pages scanned using the ADF.
• Platen Scan: Displays the number of pages scanned using the
scanner glass.
• Imaging Unit, Transfer Belt, Fuser, TransferRoller, Tray1
Roller: displays the number of pages printed each item.
5. If you selected to print a supply information page, press OK to confirm.
6. Press Stop/Clear to return to ready mode.
when you reach the imaging unit reset it then try, it should work then
