Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Jvc 66 inch projection t.v. halo repair - JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Posted by RUSS DIORIO on
Double faces with red 'halo' around people...after TV 'popped' and went off then back on.
Replace the convergence ICs and resistors. You can get the JVC repair kit called the AV48WP30 - AV65wp30 convergence repair kit from www.tvrepairworld.com which contains the ICs, Resistors, and the CD with repair instructions.
May 25, 2011 | JVC AV-56WP30 56" Rear Projection...
I opened the set and the blue projecter does not show image like the red and the green. does the blue projecter need to be replaced?
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 28, 2011 | JVC AV-56WP74 56" Rear Projection...
Have a jvc i-art pro 56" from 2003 have a red halo surrounding images. what can I do to fix this and where do I acquire the parts? Thanks
Thats aconvergence failure. You can get the AV48WP74 convergence repair kit from www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions for the repair.
Jul 10, 2010 | JVC AV-56WP74 56" Rear Projection...
RCA HD52W59 CONVERGANCE WONT SET
you need to install the RCA repair kit called the ITC222A convergence option missing repair kit from www.tvrepairworld.com the kit has the Cd with instructions.
Mar 09, 2010 | JVC AV-48WP30 48" Rear Projection...
Jvc 48 inch tv and the picture looks 3d
Convergence ICs have failed. You can get the convergence repair kit for your model JVC at www.tvrepairworld.com the kit contains both ICs the associated resistors and the CD with detailed instructions.
Jan 03, 2010 | JVC AV-48WP74 48" Rear Projection...
Everything has a halo
You will have to inspect the convergence circuit. See if there are burns on the capacitor or there could be a problem with the circuit itself.
Sep 27, 2009 | Hitachi 46F510 46" Projection HDTV
"Halo" Effect
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 19, 2009 | Philips Magnavox 55P9271 55" Rear...
Magnvox 50 inch rear projection tv
Have you tried cleaning the projectors? I had a halo issue and that resolved it. Good luck
Aug 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sony rear projection whites appear green
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Dec 24, 2007 | Sony KP-51HW40 51" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
