Question about ViewSonic GA771 Monitor
My mouse responds erratically, why? - ViewSonic GA771 Monitor
Posted by sujanthan rasaratnam on
mikadot
  • 2,113 Answers
If it is a ball track mouse, the re is lint inside and it needs to be taken apart and cleaned. If it is a wireless mouse, there is either a solid object where it looses the signal for a bit every once in a while, or the batteries are low. Your processor could be too busy with trojans or keyloggers... just in case get spynomore free to try off the internet and run a smart scan and see what it finds.
Posted on Dec 03, 2013
Cursor jumps to corner of screen, is erratic
have you tried a usb mouse ?? as if that works it will be the touch pad is playing up. you can disable it and use a wireless mouse or usb one. as it would be cheaper then replacing the touch pad.
Dec 29, 2013 | HP EliteBook 2730p Tablet PC
what type of mouse is this? track ball or laser? if its track ball try to remove the ball and clean it with soap and water, there is two gear inside the mouse one for vertical the other for horizontal movement the rod of these gears sometimes get covered with dirt which cause the erratic movement clean this with light alcohol and all will be ok
Dec 03, 2013 | ViewSonic GA771 Monitor
Hi All: I have a Microsoft Laser 6000 Mouse Model 1052 - that became erratic within one year. Tried changing to new batteries but to no avail. Any suggestions or is it toast? Cheers, Joe
By erratic, i assume you mean jumping around the screen, etc? get a qtip, cover it with isopropyl, and gently swab the lens. make sure it is free of dirt and scratches. Also clean the area you use your mouse on. It should be fine after you do that.
Mar 10, 2011 | Microsoft Wireless Laser Mouse 6000 v2.0
Mouse is erratic in its movement
Go to Logitech site and load newest software for that model. After you do this, you can customize to windows by going to control panel, mouse, etc. Hope this helps.
Jul 06, 2009 | Logitech 9311570403 Mouse
Wireless trackball mouse pointer frequently won't respond
Just took it apart and cleaned the ball thanks anyway
Dec 30, 2008 | Atlus Sticky Balls for PSP
Has anyone found a fix (short of getting rid of) for Logitech MX 600 Laser Mouse pointer erratic operation?? Seems to work OK on a Flat smooth surface, but jumps all over the place on any mouse pad I have...
  1. Mouse is not clean.
  2. Optical portion of mouse is blocked.
  3. Moisture or other material on finger.
Mouse is not clean Users who have an optical mechanical mouse (most common mouse for desktop computers) are likely experiencing erratic behavior because the mouse is not clean or is dirty. Optical portion of mouse is blocked
Users who have an optical mouse are likely experiencing erratic behavior because a portion of the optical eye is blocked. Most commonly this is caused by a hair.
Moisture or other material on finger Users who are using a touchpad may experience erratic behavior because of moisture or other material on the finger such as lotion.
Mouse has been cleaned and still has problems If you've cleaned the mouse and continue to encounter issues and this mouse has worked in the past fine unfortunately your mouse is likely defective. One additional test that can be done to help determine if this is the case or not is to connect the mouse to another computer. Otherwise we suggest replacing the mouse.
Oct 24, 2008 | Computers & Internet
98763 mouse
I had this problem and just discovered that the blue light is a button. I pressed the IDconnect button and the blue button on the thumb drive at the same time and then it worked. I think they needed to be synced.
Oct 14, 2008 | GE Wireless Optical Mouse
I have a Wireless Optical mouse 2.0 and a wireless keyboard 1.0A.  I am having an issue with the mouse not responding to pressing the keys but it is erratic.  I uninstalled both programs and...
i got a microsoft wireless mouse opitcal 2.0 at car boot sale no instrutions with it or cd can any one help i have a wireless laptop with vista 32 bit help please easy instrutione please
Jul 09, 2008 | Microsoft Standard Wireless Optical Mouse
Windows XP using Wireless Intelimouse with KVM switch exhibits erratic behavior
Hi
What type of mouse do you have plugged into the KVM ?? PS2 or USB and what type of KVM switch are you using.
Respond back and I will look into it for you.
/SPH
May 19, 2008 | Computers & Internet
ViewSonic GA771 Monitor Logo
42 people viewed this question
Top ViewSonic Computers & Internet Experts
Dimitar Todorov
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
