SOURCE: Matsui 7" digital photo frame
I got one for xmas and pics download easily every time. I connect my camera to the laptop then load the shots I want onto the SD card on the camera, disconnect and remove the SD card from the camera then insert in the frame. I have had no problems with photo size or downloading time. I do have a problem when I remove images from the SD card however. The frame still displays images that I deleted and are not showing when I connect to the laptop! Can anyone help?
SOURCE: 7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
SOURCE: transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer
Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See for applicable file formats.
1. Connect the USB cable from the frame to your computer (Connecting to your computer).
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
SOURCE: PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
SOURCE: Will not display photos
"NOT SUPPORT - RECOMMEND - 640 X 480 60HZ" You can find an update for this problem here:http://www.dsicentral.com/support/800update.html
