Sharp LC-65D90U 65 in. LCD Television Logo
Posted on Oct 12, 2007
My sharp 26"lcd tv stuck in standby,wont turn on
When i turn the tv on it stays in standby mode.have tried pressing the reset button but it did not work. model no. sharp lc26p50e.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 10, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1837
Points
I had a same problem with sharp LC-40LE340E. The service told me to change motherboard but I decided to buy a new LG TV. The sharp TV I left unplugged for a 50 days and after that when I tried again the tv started normally. I was Really surprised. Don't spend money just wait and check again. [email protected]
  • Anonymous Feb 10, 2013
2 Related Answers
Anonymous
  • Posted on May 07, 2010
SOURCE: I bought a Sharp 52" LCD stuck in demo mode
Hi jmartinezua,
Here is how you fix this:
Go to menu--> setup --> reset
This will reset your TV to factory settings. The Demo Mode will cease.
JJ
A
Anonymous
  • Posted on Feb 17, 2008
SOURCE: INSIGNIA LCD won't turn on
Call Electronics Direct to fix it in One day, Call Now 905 565 6595
Lc15av7u how to reset tv without remote
https://www.manualslib.com/products/Sharp-Lc-15av7u-2761373.html
Here is the service manual
HOW TO INITIALIZE THE LCD TELEVISION 1. To enter the service mode, press [MENU] and
[POWER] buttons on the TV unit simultaneously in
the standby mode.
2. To initialize the LCD television, press [DISPLAY]
button on the remote control unit.
3. Confirm "FF" indication on the upper right of the screen
My tv wont turn off and is flashing colors only
YOU PUT TV IN DEMO MODE, HOLD VOLUME UP AND CH. UP AT SAME TIME PLUG TV IN WHILE HOLDING ALSO POWER BUTTON FOR 15 SECONDS. SHOULD CLEAR.
2helpful
2answers
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sharp tv wont turn on seems to be stuck in standby mode?
check and replace the vertical deflection ic.also check for dry joints
2answers
My 26" lcd television FLM-2601 polaroid is not working it constantly stays in standby mode you push power button and blue light flicks on then goes right back into standby mode how do i fix this?
First of all, check your input source on your TV.
Turn on TV.
Press the Input button on your remote.
Make sure the Source Input matches the corresponding device that is wired on the back of the TV.
1helpful
My Tv wont turn on, the standby light stay orange, When i press the button it should go blue and switch on but it wont.
Hi, l had the same problem. HAD !!
l bought a universal remote control (5 euro), but unfortunetly no codes for Acer in it.
Then l did the setting up by auto search and YES : there was a code. But, wheeehh, it did not work.
A little bit sad l took the Acer control and guess what: it worked again!!!!! l guess the TV had a total reset, and l use only the Acer remote control now.....
Female and blond!
14helpful
2answers
Samsung lcd faults
Found this on FixYa and it worked:
I had a similar problem and the way to solve this is to reset the set from the remote. Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Peter
Frozen digital screen
2answers
I want to reset my TV
well when the blue light is on and ur tv is on standby, just use the channel changing button, simple!
Top Sharp Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
