No picture sound ok.power comes on 24v for inverters ok.lamps not lit.replaced inverters same trouble.
It sounds that the lamp-On signal doesn't comes from the main board. Check it. For more information go to http://electronicshelponline.blogspot.com/
SOURCE: 47inch toshiba lcd tv (HL167) black picture, but
Best to replace both at the same time . Yes they are easy if you can find the parts.
SOURCE: Red power light and buzzing sound with red lamp light.
If the lamp does not light at all, it is probably a bad lamp. The buzzing may be the ballast trying to start the lamp or a problem with the power supply. Check the lamp and see if the arc tube is broken. If its a new lamp, you should be under warranty. I have the manual if you want to go to me site at allprojectorlamps.com. Just send you email to me attention Bulb Guy
SOURCE: My TV has a 17pw26-1
No, the voltages are just fine. The fault must be either in the PMW itself or in the HT transformer - and the only way to fix that is to replace the entire inverter board.
