Cell Phones Logo
Question about Cell Phones
Iphone will not make a sound when ringing
The iphone rings but does not make a sound. volume is up all the way . it only vibrates when ringing.
Posted by patrice lambert on
rickdevisser
    New Friend:
  • 47 Answers
Did you turn on the quiet mode? top left switch on the side...
Posted on Dec 03, 2013
5 Related Answers
Anonymous
SOURCE: no sound when phone rings
I called Verizon Wireless and the said, if you go to “My Sounds” or “My Ringtones” select the song that you want to hear and press the play button. While the ringtone is playing press the button on the side of the phone to raise the volume…you should be able to hear the ringtone. Hope this helps!
Posted on Dec 12, 2007
Anonymous
SOURCE: Phone will not ring
Thanks, The orange dot on my phone was showing as well. That fixed the problem.
Posted on Feb 12, 2008
Anonymous
SOURCE: my iPhone will not ring
Did you try the switch on the left side of the iPhone?
Posted on Jun 03, 2008
Anonymous
SOURCE: iphone doesnt vibrate
I had the same problem: my phone wouldn't vibrate at all... I read a lot on other forums and found the following solution: If you turn the phone face down, and hit it on the metal side a couple of times (I hit it with just enough force not to cause it any damage) the vibrate will come back on. I almost didn't believe this, until I tried it.
Good luck to you all.
Posted on Mar 20, 2009
nige393
  • 39 Answers
SOURCE: The iPhone does not ring, only vibrates
There's a switch on the left side at the top of the iphone that turns the ringer on and off. Make sure this is towards the front of the phone to enable the ringer
Posted on Aug 06, 2009
1helpful
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
My iphone doesn't ring or vibrate, but does with earplugs on.
hey bro,
i fix more problem like your's. by change the flex up. with volume+vibrat button+headphone.
change this and all your problem will be good.
memeh Fixphone
I would try a system restore, plug your iPhone into iTunes and click restore, it will delete everything but once its done it will restore it to when your last sync was.
Iphone doesnt ring
Is the volume up fully (click on the volume buttons on the side)
Is it on vibrate? Very easy to inadvertently knock the sound switch to vibrate, which is located next to the volume buttons.
Hope this helps. Let me know if it doesn't.
BReady
I cant get my iphone to ring...it will only vibrate
I assume you tried turning the volume button up on the side and checking under Settings->Sounds->Ring Option??
12helpful
3answers
Will not ring only vibrate
when you set the ringer to ring only will it ring?
on the side of your iphone there is a switch above the volume switch that is a ringer/vibrate switch
switch it and test
1helpful
Phone does not ring
tap settings and then sounds adjust volume keys if it doesn't work try resetting your phone. tap settings go to general then reset. Goodluck.
26helpful
6answers
İPhone not ringing
you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
cheers!
Top Cell Phones Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Cell Phone Expert? Answer questions, earn points and help others
