SOURCE: RCA digital voice recorder 5013A
Press and hold MENU for 2 seconds to unlock unit. You can download the manual from the link below: http://support.rca.com/doc/Device_Documents/manuals/RP5013_manual.pdf?deviceDocId=280&navtypeid=6&pagetypeid=2&prevPageIndex=4&selectedmodel=RP5013&selectedFamily=generic&nvty=m Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: RCA Digital voice recorder model RP5022B
have you tried formatting it? press erase till it flashes delete, then press and hold record for 3 seconds till it says Format, then press and hold erase till it says wait..it should fix it if that's the problem
SOURCE: RCA RP5120 Digital Voice Manager
If you bought the recorder new still in it's package, the software is located on the recorder itself.
Plug the recorder into your computer and let the computer recognize it. Once it's loaded open a copy of explorer if one did not open already. Look for a folder named SETUP in the recorder. Inside that folder is the software. Run it from the folder.
This should correct your problem.
SOURCE: instructions for usage and operation
there's a link to a PDF of the full user's/instruction manual under the "Production Details" section here
http://www.amazon.com/RCA-RP5010-Digital-Voice-Recorder/dp/B00006LEJ9
SOURCE: Where can i get a manual for an RCA Digital Voice
Click HERE
for the manual. Scroll down on the page and insert the validation code on the page to activate the download link. I hope this helps and good luck!
