Question about Amazon Kindle Fire HD
Installed a new router and now my speakers don't work. How do I fix this?
Posted by Debbie Ulsperger on
  • Debbie Ulsperger
    Debbie Ulsperger Dec 03, 2013
    Problem is on my PC, not Kindle Fire HD.
Ena Schiebli
    New Friend:
  • 10 Answers
I lost the sound on my computer once and someone told me to go to my sound device ( which is RealTek) in device manager. I right clicked on it and clicked "disable". Then right clicked on it again and clicked "enable". For some strange reason this worked for me. Sometimes adding or downloading something can cause a glitch. Also, have you tried restoring your computer to an earlier date when your sound was working? That is, "System Restore" in Control Panel.
Posted on Mar 17, 2014
Carl Morris
    Novelist:
  • 180 Answers
The router change shouldn't have any affect on your sound or your speakers. You need to start checking things out. Is sound accidentally shut off at the speakers?? Have speakers came unplugged at back of computer?? Has the sound been mistakenly shut off at the keyboard?
Posted on Dec 03, 2013
I recently installed the amazon alexa app on my kindle fire and then it connected all my other devices. It was working until I installed a new router today. Now I can not seem to connect. Help
You likely need to reset the wi-fi connection for Alexa so that ti connects to the new router. Make sure that the IP addresses are the same from the old router to the new one. Some use a host number of 192.168.1.1 and others use 192.168.0.1. And of course, if you changed that, you need to match Alexa to the new IP range. Plus verify that the SSID and access password are the same on the new router as you used on the old one.
Jan 03, 2017 | Amazon Tablets & eReaders
How do I fix my tablet to connect to the internet/google?
Delete and reinstall app, restart tablet, Do you have any vpn installed, what about firewall? turn all that off and see if that fix the problem? It may be that router have firewall and is limiting you.
If that doesn't help, put tablet to factory settings, if you are not sure about router reset that to, as it may be collaborate joke (it wouldn't be the first time).
Apr 04, 2016 | Tablets & eReaders
How do i restore my laptops and tablets to factory settings?
Make sure you are connected to the Internet so you can download the latest copy of Mac OS X.
  1. Use an app like SuperDuper or Carbon Copy Cloner to clone your internal hard drive to an external drive. This enables you to access all your old files, and the drive can be re-cloned to the internal drive if you want to restore your Mac.
  2. Deauthorize your iTunes store account. (You should also deauthorize any third-party apps, such as Photoshop, that are locked to your Mac).
  3. Turn off FileVault (if you are using it).
  4. Sign out of iCloud.
  5. Restart the Mac in Recovery Mode (hold down Command and the R key during restart).
  6. Use Disk Utility to erase the hard drive. Click on Disk Utility > Continue. Select the main volume and click Unmount then Erase). Quit Disk Utility (Disk Utility > Quit Disk Utility).
  7. Click Reinstall OS X and Continue. Follow the instructions to reinstall Mac OS X.
How to reset Mac restore your Mac to the original factory settings
iPad
Settings-General-Scroll down-Reset-Erase all content and settings-Then confirm. Erase All the Data From Your iPad to Make it Like New
Sep 28, 2015 | Apple iPad Tablets & eReaders
If speakers of 10" tablet blow who will fix it and how much does that type of repair cost ?
it depends from speaker used in tablet..if it is from china market the speaker cost max 5$..you can replace the speaker it is conected with wires just cut the wires and conect the wires from new speaker..you can find the speaker on ebay
Feb 26, 2015 | Tablets & eReaders
Kindle fire will not connect to wi-fi which it has before and other products connect with no problem.
1 Reset your wifi Router;
2 FORGET your router details on your Fire and then rescan to find it again, reconnect.
It's possible that a neighbour has a new router, tv, telephone, bluetooth device and it's causing interfearance on your wifi settings. If the above simple fix does not sort things out you may want to go into the router and change you channel to a fixed service on channel 3-9 rather tahn AUTO.
Good luck
Jan 27, 2014 | Amazon Kindle 3G
I just purchased a Nook eBook and I need my WiFi password to make it work. How can I create and reset a new password?
I assume you already have WiFi, if you don't, I suggest going out to wal-mart and buying a cheap wireless router to get you started. Then the instructions should explain how to get the password set up.
If you already have WiFi and the problem is that you forgot your password, then this should be able to be fixed easily if you know or have not changed the password for your WiFi router. Below is a set of steps to resolve the issue. The only requirement is a computer connected to the same router via WiFi or Ethernet.
1. Open Command Prompt (in windows) or open Terminal (in Mac OSX) 2. In the command line, enter "ipconfig" and press enter. 3. Look for Default Gateway and remember the corresponding IP Address. (Format: ###.###.###.###) It might look like 192.168.2.1 but not necessarily. 4. Remember that IP Address (write it down, copy it, do something). 5. Open your favorite web browser and enter that IP Address into the URL box. 6. This should ask you login, if it doesn't, skip step 7. 7. use the username that you set up the router with, or if you didn't change it, try using "admin" as the username and "admin" as the password. Try not using a password. If you still can't figure it out, use google to try and find the default password for your brand of router. 8. Once logged in, you can restore factory settings, or change your WiFi Password.
Having more information would have been helpful. (Aka - Router Brand, Is it your router, are any computers connected to it) Hope this was helpful.
Jul 17, 2011 | Barnes & Noble nook color eBook Reader
Cannot connect my router to get wireless for my ipad2. I have a d link 624. How do I reset it?
Hey,
I believe there should be a tiny reset button in the back, which you'll have to press for 15 seconds using a paper clip. This will reset the ENTIRE configuration of the network, so it will reset with the DEFAULT username and password, which you might have to call D-Link if you don't have the information.
There's more information on that over here: http://www22.verizon.com/residentialhelp/fiosinternet/networking/troubleshooting/questionsone/86195.htm
Just a note: it might not necessarily be the router's fault because I've heard that many people had problems with their iPad's wireless network after they updated to the newest firmware, which is 4.3.3. So, if you don't want to do mess around with your router, you can either wait for a new software update, or downgrade it, if you have the necessary files.
Good luck, -virjog
May 17, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Hi i have a gateway laptop, im having a hard time fixing the speakers,it started wen i tried to use my speakers for my ipod.when i took the cord of my ipod out of my laptop,the laptops speakers arent...
You have possibly broken the switch, inside the units Phono Jack, this is a common thing, there is a little switch, in the Jack, that cuts OFF the Internal speakers, when used. Sometimes the ball on the end of the Plug can force the contacts too far apart and they don't make contact and cut off the internal speakers. This is a difficult fix, as the whole laptop must be disassembled, the part unsoldered, and another good part re-installed. As a cheap workarround, get an inexpensive USB soundcard, and some small external speakers. Otherwise it's off to the repair shop, or get yourself a service manual and do it yourself.
May 18, 2010 | Tablets & eReaders
V210 Internal Wireless not working?
welcome to fixya
you might be able to update the driver through the devie manger find the wireless card and right click it and hit update driver this might fix the problem if not
there is a place that might be able to help it is call driverupdates.org this program they have is free to download but you have to pay for the drivers to be installed might be worth it
i would try device manger first
goto start and search for device manger once you find it there wil be a list of items in your computer find the wireless modem and then right click it and hit update drivers and it might take a while but still should update it if needed
hope this helps you out have a good day
Aug 05, 2008 | ViewSonic AirSync V210 Tablet PC
Amazon Kindle Fire HD Logo
74 people viewed this question
Top Amazon Tablets & eReaders Experts
Jax Planet
Jax Planet
Sheldon Dedek
William Alequin
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
