Was making popcorn when sparks started coming from around the kettle. Then it quit. Then unplugged the popper. Plugged it back in and nothing works but the heat lamp.
The motor output shaft bushing might have came loose I have seen where it falls out of the motor and the shaft becomes real wobbly and it will cause excessive wear in the kettle cross bar bushing too. also make sure the cross bar and lid assy. is not come loose from the kettle.
Unplug the kettle and check voltage at the kettle reciprocal . If correct voltage is there with the kettle switch on put a ohm meter across the hot and neutral terminals of the kettle plug . If there is no continuity between them either a wire burned off in the kettle or the thermostat is bad. When they go out its usually open so no power will go thru it.
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
There are no replacement parts for Nostalgia Electrics equipment.
Double check that the kettle is plugged in, that the switch has power. If inclined open kettle and inspect wire connections and continuity, beyond that the popper is not fixable.
The instructions say make sure kettle motor is plugged in. Turn unit ON with switch on crown of machine. Allow unit to run for 3-5 minutes to heat up kettle. Turn unit off. Add 2 teaspoons of your favorite popcorn cooking oil to the kettle. Then add 1/4 cup of popcorn kernels to the kettle. Turn the unit on and close the door. When popping sound slows down turn the unit OFF. Flip the kettle over with the crank handle to empty the kettle. Repeat process until desired amount of popcorn has been popped.
I have a Popcorn machine from Nostalgia too that had this problem. I cleaned it out and everything but it still had the problem of the it getting stuck. After days of analizing, I found the solution. after a while the ceiling of the popcorn machine starts to fall in, lowering the handles of where the kettle goes. making the knob that turns being lower that the one that makes it turn, causing it to get stuck, all I did is add so leverage so the kettle is once again at the same level or higher. Making it turn with greater force and not getting stuck. In other words make sure the turning mechanism is leveled and not one lower than the other. preferably the kettle part being higher.
I hate to put this as a solution because it really isn't. I have an old popper needing a new kettle and was told it was almost as much to purchase a new kettle than the whole machine. The kettle is almost the entire cost of the unit. I will be purchasing a new unit.
