Question about Maytag Washing Machines
Maytag quiet series 100 noise during washing
Roaring noise during wash cycle
Posted by Bruce Edwards on
Qwert Adams
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 66 Answers
Roaring noise must also come during the spin cycle I suppose...it seems your bearing and or drive belt/gear is causing you this noise. To fix this, you would need to completely disassemble the washer and inspect the bearing and or drive box that activates the turning motion. It is a large job.
Posted on Dec 02, 2013
  • Bruce Edwards
    Bruce Edwards Dec 03, 2013
    Thanks. This makes sense too.
  • Qwert Adams
    Qwert Adams Dec 03, 2013
    Remeber people...safety first...PLEASE always unplug an item when inspecting it...take your time and dont rush into it. Have the proper tools and dont get frustrated...be prepared to not being able to fix it and being able to put it all back together again or else the mechanic that will fix it will charge you double. Take pictures before you disassemble anything....but please...unplug it first....dont be a hero.
5 Related Answers
Anonymous
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Posted on Dec 06, 2008
Anonymous
  • 30 Answers
SOURCE: maytag washer noise during wash cycle
Check for the tighten nut to agatator is tighten. If agatator is lose it floats up and down during the wash. There is a lock ring (rubber) on the shaft that holds the agatator on, check this, if off replace thid . If the agatator is still in good shape can still use it , if not pull of and replace it. This work is't hard to do.
Posted on Jun 02, 2009
Anonymous
SOURCE: high pitched buzz/whine during wash cycle only, spin fine
my new front load washer makes a high pitch sound when water is going into it
Posted on Oct 07, 2009
Tijerrex
  • 27 Answers
SOURCE: The washing machine started making a grinding
sounds like a bearing... although it could be the water pump... water pump is an easy fix... bearing is not an easy fix... take the belt off the bottom of the pump (under the machine) and see if it spins freely by turning it w/ your hand... or if it seems really stiff... if it looks good then it's def. your bearing...
Posted on Jan 15, 2010
Maytag quiet series 100 dishwasher won't complete a wash cycle - just keeps running and running until I turn it off after 2 or 3 hours
washer timer is faulty, gets stuck, if this occur more often , you definite need parts replacement on the washer timer switch.
Dec 28, 2013 | Maytag Washing Machines
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
Thunping or banging noise during wash cycle may tag MVWC300VWo quiet during spin
You will need to pull the basket and check the drive block.
Here is a video to show you how to get to the drive block.
Dec 03, 2012 | Maytag Washing Machines
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
Maytag dishwasher legacy 300 quiet series
Check for foreign objects like glass or plastic at the grinder blades. Some dis assembly will be required. See appliancepartspros.com for diagram.
Mar 22, 2009 | Maytag 24 in. MDBH955AW Built-in...
Washing Machines Logo
345 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
