Sewing Machines Logo
Maria-Luisa Olmos Posted on Dec 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello I just bought an elna 3005, it worked fine for two days then, I don't know why, it stated doing two stiches forward one stich back, on all the different stich settings. What's happened? Thanks
Debbi's Sewing Machine Repair
Level 3:
  • Sewing Machines Master 7,365 Answers
  • Posted on Dec 03, 2013
Level 3:
Answers
7365
Questions
Helped
1744382
Points
19451
Sounds like there is something wrong with a cam or gear, I suggest taking the machine back and getting another one
4 Related Answers
A
Anonymous
  • Posted on Apr 11, 2008
SOURCE: satin stich scallops
stitch no. 29 "F "foot 7.0 width 0.4 length tension 2-3
Anonymous
  • 69 Answers
  • Posted on Feb 12, 2009
SOURCE: yamata FY7568 only stiches ----------
Have you changed your needle? If you have a dull or bent needle it can cause the machine to not lock the stitches together and the result is a straight stitch on every pattern. Also, check your stitch width selector and make sure that it did not get accidently moved.
Anonymous
  • 1788 Answers
  • Posted on Sep 12, 2010
SOURCE: I have a frister and
Why not google the name and you will see lots of sites concerning these machines? I am sure that you will love the history of them and who knows you may run into a collector who has some answers for you. Good luck and happy hunting
sylviaivie
  • 1564 Answers
  • Posted on Mar 20, 2013
SOURCE: 1960s Elna Supermatic - lower thread only catches sometimes
Make sure you have the correct needles for this machine and that it is fully inserted into the needle bar and correctly oriented.
Elna 3007. Tried a stich other than straight and when back to straight the machine does several stiches forward, then back, then forward and so on. I cannot get out of this mode adjusted selector
My guess is feed dog interference. Clean out bobbin, hook, and feed dog area.
You might first try lowering and raising feed dogs and see if problem goes away.
2answers
Elna 3007 reinforces every stitch.
It is in Stretch Stich mode....(SS)
Check your manual to reset in normal mode
My stiches keep missing a stich
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
if these suggestions don't help the the machine could be out of
time & the machine would need to be taken to a sewing machine
shop to be checked
1helpful
The 6 built-in stitches (such as blind stitch, darning stitch, etc.) are not working, they only just do the basic zig zag stitch. Also the cams for decorative stitching do not work either. These are all...
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
1helpful
My Elna SU will only do straight stitching it will not zig zag
Yamata FY7568 only stiches ----------
Satin stich scallops
Machine is not making stiches
Probably nothing serious. I suspect it is incorrectly threaded. Check the needle is in right and rethread top and bottom according to the manual. There are some good youtube videos showing this if you do a search there.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
