Question about Emerson EWF2703 27" TV
SOURCE: how to change the input
First, the bad news: Unfortunately, you are correct - the only button to change inputs is on the remote, which you no longer have.
Now, the good news: You can buy a universal remote, set it for your TV model, and have control of your inputs again. The first link below is for the URC R6, which is available at any Walmart for about 20 bucks. You can set it up for an Emerson TV, no problem. Here's the link for it:
http://www.universalremote.com/consumer/products.php
Also, here is a link for the owners manual to your Emerson EWF2703, in case yours has gone missing with the remote:
http://www.emersonaudiovideo.com/pdf/om/EWF2703.pdf
Not a perfect solution, but it will work, and it will work just as fast as you can get to your local Walmart or equivalent.
Cheers
Posted on Nov 05, 2008
SOURCE: change input without remote. can be done on tv?
If you don`t have input selector on the set or in the menu you might be able to get it with the channel buttons, that would be right below channel 2 or above 125
Posted on Oct 31, 2009
SOURCE: lost remote control for an emerson tv. how do you
I just purchased one of these televisions and it didn't come with a remote. However, a Philips Universal Remote (SRU2103/27)
with a code 0520 works fine. I haven't explored all the codes but I can easily change from tv stations to Video 1 and Video 2 merely by pressing the "Input" button on the remote.
Posted on Dec 08, 2009
