Question about Saeco Odea Go
Saeco Odea Go descaling
Hello. I performed the descaling process last summer and I need to do it again. The problem is I lost the manual and I also forgot how to do it. I searched the Internet but I don't remember to do the descaling like that. I remember the descaling solution flowing from the dispensing head and steam spout both. I really need help urgently. Best regardes, Nathanael.
Posted by Nathanael98 on
nikolay nikolov
    Habit-Forming:
  • Saeco Expert
  • 152 Answers
Fill the tank with detergent and let the hot water run for about 15 seconds. Then turn off the machine for about 15 minutes. Then turn the machine back and let the hot water. Then rinse the water tank and fill it with clean water. Run hot water again to empty the tank. Fill clean water again and then you can put down coffee :)
Posted on Dec 07, 2013
5 Related Answers
Coffee pup
Merry Johnson
  • 3 Answers
SOURCE: How to descale machine
you can download and print a manual for your Saeco here
ttp://www.manualnguide.com/download/manual-guide/saeco-odea-go-instruction-manual.html
Posted on Dec 12, 2007
Anonymous
  • 515 Answers
SOURCE: Water flows from steam spout
you have to take it to a Saeco service center to replace a gasket in the steam valve.
Posted on Jul 11, 2008
Anonymous
  • 11 Answers
SOURCE: descaling
You can download a user manual for your saeco coffee machine here: http://www.coffeeshrine.com.au/user-manuals/
let me know if you have any specific problems once you have read the manual.
Posted on Nov 13, 2008
btmachi
  • 81 Answers
SOURCE: Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Posted on Feb 03, 2010
btmachi
  • 81 Answers
SOURCE: I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Posted on Mar 28, 2010
How to open the saeco odea
After descaling and rinsing, you need to hold the hot water button for 6 seconds to reset the descaling indicator.
Hi, I've got a saeco odea giro plus. 3 weeks old, the descaling ight came on. I followed descaling steps in manual. rinsed off brew group and place it back in unit. now the system will prime, grind, I...
Look at the brewing group where the top strainer is. The small holes are blocked with coffee. The water can not pass through them.
You will need to unfold the two screws at the top and then remove the strainer, grow and clean it and clean it if the holes are blocked.
Do this only
1helpful
I have lost the descaling instructions for my Saeco Odea Go, could you please help
Go to Saeco.com and there the manuals are on line. Can print it out or save to your computer.
9helpful
Flashing Red bulb
That is the descale light, you should run a descale through the machine. After you have done that hold on the water button and the descale light will go away
12helpful
Red light is on (looks like an M) and I don't know why??
It means time to descale , however if you want to get rid of it, just press and hold the water button until it goes off.
To descale..fill the container with descaler and let water goes through the system by openning the valve and catch the descaler with a container. Turn off the machine a few minutes and start the process all over again for 1/2 hr, and finally with water to wash the system.(donot want to heat up the descaler too much)
1helpful
Descaling Saeco Odeo Go is illegi
The descaling details appear on page 23 onwards of the official manual, which is available for downlaod from this link:
http://www.saeco-usa.com/en/manuals/manuals.html
Hope this helps.
1helpful
Saeco odeo giro and the red squiggly light
This is the descaling indicator.
If it flashing your machine needs descaling.
1helpful
Saeco Odea Go Logo
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
eyecam
Ekse
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
