Question about Compaq Presario CQ56-115DX Laptop
Backlight won't turn on
My backlight won't fully turn on. it turned just fine last light, then i turned it all the way down. This morning, it won't light back up. there's a red light by where the charger plugs back in, the light is usually white. Neither the light button nor going to the data option to manually turn it up work. When i manually try, it slides to say it's on but it won't stay on.
Posted by Austin Bridges on
ainthard
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 95 Answers
Your laptop probably in power saving mode, it is a preset to makes battery last longer. your power adapter might not being detected shown by red light, try to plug it firmly or use other power adapter if available
Posted on Dec 02, 2013
5 Related Answers
sandrew
andrew pester
  • 2961 Answers
SOURCE: backlight fading
you can adjust the brightness by pressing the Fn button along with the *left/*right button on the right side of the keyboard
Posted on Oct 22, 2007
Anonymous
  • 101 Answers
SOURCE: my lcd backlight has burned out
There are four options. One is to replace the entire LCD Panel. Not cost effective but probably the easiest. Two is to replace the flourescent tube, but this requires unmounting the panel from the laptop, disassembling it, desoldering and soldering the old/new tubes, reassembly and remounting. The time and hassle is not worth the amount spent on a new LCD (besides, the flourescents are very fragile and break easily, plus they are made with lead so you must wear gloves for the replacement procedure). Three is that you can use an external monitor, so long as you have no reason to move the laptop. Fourth is buy a new machine.
I would probably look on eBay for a known good used panel or even a dead system on the same brand/model which has a good LCD and then change the panel myself. It is not that hard, especially if you find the right service manual.
But how do you know it is the backlight? It might also be a bad inverter. An inverter is about $30 where a new LCD would be $150 or more, and even a used one might run $75. Best to try to find a non-working used system with no video problems, or maybe even a complete replacement top on eBay so you have all the parts you might need.
Posted on Dec 30, 2008
Anonymous
  • 41 Answers
SOURCE: Compaq R3000 laptop screen went black
Give this a try -
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Let me know if it doesnt work.
Posted on Jan 20, 2009
Anonymous
  • 3 Answers
SOURCE: My compaq 572US was on sleep and now when I hit
its a defective graphics card...there is a class action lawsuit for this model and many others. search nvidia class action lawsuit. you can get it repaired or replaced with the settlement terms. I have same laptop, same problem!
Posted on Sep 29, 2010
Margaret Glanville
  • 1542 Answers
SOURCE: when i turn on the
Hi
I know this may sound silly but have you tried starting it up with the power adapter switched on and plugged in
Posted on Nov 18, 2010
Blank screen with blue light
Hello
Check the backlight inverter board to your TV. This is a common fault for most of the LCD TVs. If it is faulty, the backlight won't light up, resulting a balck screen with sound.
This is the picture of the backlight inverter board to your TV. OK.12_23_2011_4_29_45_am.jpg
Dec 23, 2011 | Sceptre X400BV-FHD 40 in. LCD TV
Had the LCD TV For 5 Years, no problems, then just before going to bed i was about to turn off the tv when the screen went black but sound was fine. I switched channels and you could hear the channels...
Your problem can be related to either LCD backlight inverter failure or T-con board failure. Please turn on your tv, darken the room and see if you notice a dull glow on the screen. If you see a dull glow then backlight is functional and the t-con is dead. Otherwise it can be a backlight inverter failure(in some cases the backlight itself). In that case I would try replacing the backlight inverter board and hope its not the backlight as the backlight is embedded into the the panel and the only way to replace it is to replace the panel.
Aug 29, 2010 | Televison & Video
Tracker 5600 cant see display worked fine last week
Last fishing trip was at night and due to the brilliance of the display my son turnred it down and unknown to me actually turned it off ( the backlight) and it was only after trying everything else found it was the simple solution of turning it (the backlight) back on. oops
Jan 05, 2010 | Navman Tracker 5600 GPS Receiver
Shutdown laptop ,turned it back on this morning and the screen is black,no picture, nothing. battery is fully charged. the touch inductive panel and multi-media buttons are all on.
There is only 2 reason why the screen is black. Your LCD backlight is broken or your LCD backlight inverted need to change. Bring your laptop to expert technician to replace that.
Jul 23, 2009 | Computers & Internet
Dell Inspiron e1505 Backlight issue
when you leave the computer for a long time inactivity it goes to hibernate or standby
you can change it on control panel power options
Jul 10, 2009 | Dell Inspiron E1505 Notebook
Sony bravia kdl40s2010u
A 4 flash indicates you have a backlight problem. Either the backlight inverter boards have failed or you have a backlight that has failed in the LCD panel. You will need a technician to check the set to determine which is the problem.
Nov 08, 2008 | Sony Televison & Video
Nokia E61 LCD Light Black Out
I have the same problem too. The backlight won´t work. Is there a way to fix the backlight by substituting it?
Sep 13, 2008 | Nokia E61 Smartphone
Monitor is completely black
Could be a problem with the LCD backlight or the LCD ribbon connector fault. I would recommend taking it to a tech to get it serviced.
May 14, 2008 | Toshiba Satellite A105 Notebook
Ibm t20 no LCD backlight
while the T20 is on and manifesting the dim display....
1. try to slowly close the lid (but not totally closing it) and then pulling it back to its original position slowly. Tell me if the light goes back.
if by doing that action the backlight lights up, you are most likely faced with a Flex cable problem. You might need to buy this from ebay. (dim display problem in T20 series is very common these days due to wear and tear of the flex cable)
2. Also try to use a pen to turn on and off the limit switch that triggers the backlight. This is located above the keyboard below the lcd. See what happens.
Apr 10, 2008 | IBM ThinkPad T20 2647 Notebook
Truly MP3 13X only showing blue backlight
same here, you just have to keep messin' with (pluging it into computer, etc.). I know it sounds strange but that's how I deal w/mine. It eventually comes back to life.
Feb 21, 2008 | Truly MP313X 1 GB MP3 Player
Compaq Presario CQ56-115DX Laptop Logo
62 people viewed this question
Top Compaq Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
