SOURCE: Pellet stove
i have a goodman furnace 1 yaer old and the burnner mainly late at night keeps cycaling on and of no codes present
SOURCE: cheap charlie pellet stove/pel-pro runs for 10min then shuts down
The auger is controlled by a T-stat on the side of the combustion chamber. Open the side of the stove and you can see the auger motor and the thermostat that feeds it. It has a manual reset button on the back of the thermostat, press it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: plugged feeder on pellet stove
if u can get at it you can clean it, if you get at a little of it you may be able to hit it with a small brush or paper clip or finish nail or whatever while it is revolving. I spraye my old stoves auger with PB blaster then cleaned it and of course let it air out for 2 days as that is flamable. The cause is probably inferior non-hardwood pellets. Been there....and doing that .. good luck
