Brother MFC-8860DN Printer Logo
Posted on Oct 12, 2007
How to switch from "offline" status to "online" status
I can't send a wireless "print" transmission from my laptop.  The error message says printer is "offline" (I'm sure its a simple procedure/setting to get it "online" again and resume printing, but I can't find my manual and I can't figure out how to get it back "online")
  • 4 more comments
  • joyski1 Nov 26, 2007
    How do I change the status from Offline to Online?
  • whiteflower Dec 15, 2007
  • ziipppp May 30, 2008
    I have the same problem with my 9860CDW. The only way to fix this that I've found is to restart the computer, which is a huge pain.
    I'm running Vista :-(
  • csmith2 Jul 22, 2008
    My Brother MFC-8860DN Printer is checked offline and I can't ut it back online. It was working before but somehow quit working on all my (4) network computers?????
  • ezskippy Aug 05, 2008
    I have the same problem with my Brother MFC-885-CW. It is checked offline and I can't ut it back online. It was working before but somehow keeps returning back to the same problem. Even rebot does not help?
    Callie
  • Anonymous Mar 20, 2014
    getting printer to be online so I can print from my laptop
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
7973
Points
5
I had the same problem with a Brother MFC-6490CW AIO printer. Here is how I resolved it:
Open the printers folder.
Right-click on the Brother printer and display the Properties page
Select the Ports tab.
In my system (Vista Premium), the selected port was a WSD port (whatever that means). Further down the list, there was a TCP/IP port that was obviously created by the Brother installation software. I selected the Brother-created TCP/IP port (which deselected the WSD port), applied the changes, and suddenly my printer was online. No idea what the difference between these two ports is, but I'll stick with the TCP/IP port until further notice.
John Borish
Level 1:
  • Posted on Jul 07, 2021
John Borish
Contributor
Level 1:
Answers
Questions
0
Helped
7973
Points
16
Nice article! thanks for sharing with Us. Are you looking to fix Brother printer offline issues follow the step-by-step process on Windows 10 or Mac?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 30, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
10418
Points
My MFC-6490CW goes "offline" when I connect to the Internet. I have a Netgear router and it pings fine. When I unplug my cable modem, it works again. This just has to be a simple setting somewhere! Un-installed, re-installed. Reset router to default. Un-did all firewalls and antivirus. made it a static address. Reserved its IP address. Blah blah.
  • shwetaroyzad Feb 19, 2012
    my pc is offline when connect to internet, how can i connect online
Printer is offline and not printing
hi
Change a printer's status from "offline" to "online" Windows 10Troubleshooting offline printer problems.
11helpful
6answers
Epson printer offline
In this section, we provide some practical ways to resolve the Epson Printer Offline Issue. Simply follow the mentioned teachings carefully and fix this error on your own.
If your Epson printer is displaying an offline message, it means that there is some connectivity problem between the Epson printer and PC. ... Incorrect printer settings where your printer is not set as "Default Printer" may make your printer go offline. An outdated printer driver may stop your printer from functioning.
In the same way, How do I put my Epson printer back online?
Verify The Printer Connection
Update Epson Printer Driver
Check Printing Status
Restart The Print Spooler Service
Add A Second Printer
Hopefully, now you can surely Resolve this issue. I Hope, this content is valuable for you to solve the Epson printer says offline windows 10.
Epson Printer Not Connecting to WiFi
Epson Printer is Not Responding
3helpful
2answers
My HP deskjet D4260 is offline. I have tried everything to resolve this but cannot find a way of etting it back online. Please help
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online.
    PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. - Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. - Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
    Mac Instructions - Open System Preferences by clicking on the icon in the Dock. - Go to the Print & Fax control panel under the Hardware category. - Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. - Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
10helpful
My canon printer says it's offline. how do i fix this?
Go to Start/Control Panel/Printers and faxes. Right click on the Canon icon and click on Offline turn toggle it back to Online. Please rate this answer.
Cheers
Bob
11helpful
2answers
Print status: error - offline what does this mean? I have a PSC 2355 all-in-one
Printer status offline means that, the printer driver and the application has been installed, but the printer and it spooler services are idle
To resolve this issue:
Goto control panel, click on printers and faxes, a window will open showing you all the printers you have or have had. The current printer will have a checked mark. Highlight it and right click, you will see printer offline in the box, click it. That will turn the printer online and you can print.
4answers
Dell printer 1710 n .
In Control Panel - Printers, Right-click the Dell 1710N and remove check for Offline.
Norman Weimar
Norman Weimar
k24674
