Question about Konica Minolta Office Equipment & Supplies
7216 machine problem c14a3
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Expose lamp failure. The big lite under the the big glass is out
Posted on May 04, 2020
Where to find konica minolta 7216 driver windows 7 64 bit
try this site, that is legacy Konica Machine don't know if they have it
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 12, 2016 | Konica Minolta Office Equipment & Supplies
What can I do when my Konica Minolta bizhub 160 says machine trouble, service call (C14A3)
C14A3 means IR fluorescent lamp fault. Check the Exposure Lamp (LA2) . The Scanner Exposure Lamp fails to turn ON. Test the voltage supply & the Lamp.
Nov 04, 2014 | Konica Minolta bizhub Office Equipment &...
Konica 7216 how to reset Machine troubles, Call Service COF32
You need to change the developer, the code will not go away otherwise.
Aug 27, 2014 | Konica Minolta Office Equipment & Supplies
I am getting an error message that says error C14A3. How do i fix it?
The bright that normally come on under the big glass is having issues, replace the scanner assembly can't just get the lamp.
try this web site for starters
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jul 07, 2014 | Konica Minolta bizhub 161f All-In-One...
We have a photocopying machine in our office LANIER 7216. Since 3 years we have been using another brand which has more capabilities, but now it's not working and service personel took it for mending....
i dont have knowledge of lanier machines.but the ultimate answer to ur question is that remove the button cell from the main board of the machine for 30 min and then power on the machine without it.refit the cell and wola the password is broken as in other machines
Jun 02, 2011 | Office Equipment & Supplies
IM GETING A C14A3 SERVICE CALL ON TH SCREEN
This code means your scanner lamp, the one that lights up under the glass is not coming on properly. Usually this code will reset and the machine will work again. In some cases the scan lamp has gone bad and must be replaced.
Aug 17, 2010 | Konica Minolta DiALTA Di1610p Printer
Bizhub Di1610fp
C0500 code that is fuser.try reset this one first by powering machine on while holding down STOP BOTTON ON THE OP PANEL
hope that help
Oct 10, 2008 | Konica Minolta DiALTA Di200 Copier
Konica 7415 erro code C14A3
You have a blown exposure lamp or fuse. When repaired code will automaticaly reset.
Oct 15, 2007 | Office Equipment & Supplies
62 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
