Question about Faberware FSRC100 10-Cup Rice Cooker
Ampere specification of HRC-15WS hanabishi rice cooker
What is the rice to water ratio for cooking rice in the rice cooker?
Here's a simple one page guide for cooking rice in a rice cooker. It will tell you how much water to add depending on the type of rice you're cooking - How to cook rice in a rice cooker
Sep 17, 2011 | Hitachi RD5086P 8.3-Cup Rice Cooker
Where i find sunbeam rice cooker fuse in midrand
sunbeam rice cooker dead
I have a sunbeam rice cooker working fine and all sunden there no power on the rice cooker. I have test the wall outlet power input which is working fine. I assume the fuse inside the rice cooker burn out the fuse. I could not located the fuse from the inside as opend up everything from the bottom panel rice cooker .Please email to me at [email protected]
thank you
Jun 03, 2010 | Rival RC160 16-Cup Rice Cooker
RICE COOKER WILL NOT COOK RICE
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Jun 01, 2010 | Cuisinart CRC-800 Stainless Stell 8-Cup...
RD4056P 5.6-Cup Rice Cooker: We have long-grain white rice. No directions on h...
heatman101
May 17, 2010 | Hitachi RD4056P 5.6-Cup Rice Cooker
Need directions on how make rice on my oster rice cooker
There are many types of rice. Follow specific directions for variety used.
2. Accurately measure rice and water then combine in rice bowl.
Pour specified amount of water in water reservoir. Cover and steam.
3. For softer rice, increase by 1 – 2 tablespoons the water mixed with rice
by the specified amount of water on the chart. For firmer rice decrease
water mixed with rice by the same amount.
4. Check doneness and consistency of rice at minimum time specified
for each type, stirring rice at the same time.
5. When checking/stirring rice, be careful not to drip the condensate into the
rice bowl which would reduce the quality and flavor of the steamed rice.
6. Use only clean water in water reservoir
7. Rice may be seasoned with salt, pepper or butter after steaming.
Combined In Rice Bowl Approx. Time
Type of Rice Rice Amount Water
(Minutes)
Brown
Regular 1/2 cup 1 cup 42 – 45
Parboiled 1 cup 1-1/2 cups 45 – 50
Long Grain and Wild Rice Mix
Regular (6 oz. pkg.) Mix 1-1/2 cups 50 – 55
Quick Cooking (6-1/2 oz. pkg.) Mix 1-3/4 cups 18 – 20
Instant 1 cup 1-1/2 cups 15 – 18
White
Regular 1 cup 1-1/2 cups 45 – 50
Long Grain 1 cup 1-2/3 cups 50 – 55
Oct 25, 2009 | Oster 5712 10-Cup Rice Cooker
Purchased Durabrand Rice Cooker model HRC 18G working fine Is there a User manual for this cooker? All that is needed is ratio of water to rice including plain long grain and Basmati rice for 1 - 4...
Instructions quoted from the Durabrand Rice Cooker model HRC 18G manual...... 1 cup of uncooked rice rice will make about 2 cups of cooked rice. Add rice to the inner pot. Maximum four cups uncooked rice for the model. Many varieties of rice can be used including basmati, wild rice, arborio risotto, saffron rice and long grain rice. Whole grains, such as barley can also be prepared with the rice cooker, follow instructions on the package.
For every cup (160ml) of raw rice, add 1-1/2cups of water. For stickier rice add slightly more water, for fluffier rice use slightly less water.
When your rice is cooked, the cooker will automatically switch to the warm function and the yellow warm light will turn on. The cooker will stay in the warm function untill is disconnected from the wall outlet. The cooker will keep the rice warm 158F - 212F
Hope this helps, its quoted right out of the manual I have for my cooker
Jul 27, 2009 | Kitchen Ranges
Instructions/Manual needed
all rice cookers are the same 2:1 that is 2 cups water and 1 cup rice .... i like my rice fluffly so i allways add a 1/4 cup extra water . dont forget to put cover all the time its cooking and only open to stir
Feb 23, 2009 | Homesmart HRC-10 WI Rice Cooker
Oster 4704 rice cooker
you dont need manual... it a rice cooker.. 6 cups of rice = 6 cups water... no need for manual. press cook then the rice cooker will do the rest
Sep 20, 2007 | Oster 4704 7-Cup Rice Cooker
Faberware FSRC100 10-Cup Rice Cooker Logo
37 people viewed this question
Top Faberware Kitchen Appliances - Others Experts
Dennis
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Faberware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
