Question about Samsung ML-2550 Laser Printer
Outbin full - Samsung ML-2550 Laser Printer
Posted by masoud on
  • masoud
    masoud Dec 02, 2013
    outbin full
HP M4345 shows left outbin is full. Done: Checked all the jams, readjusted formatter, cold reset, changed dc controller. what to do?
Check the flag in the output assembly that is triggered as each page is ejected. If this flag is broken, then the system will think that the output is full and stop operation. Have you done a complete sensor test through the diagnostics menu yet? You have replaced a lot of parts without stating you tried that first. I have never had a bad formatter trip this error and the sensor are connected to the DC controller not the formatter.6b88c583-d091-4e71-a58e-3bd584ca34f9.jpg It may be a problem with the stacker. Do you have the original standard output tray that you could install to test? The output sensor is position "L" in the sensor test list.
Outbin full
Dear
The sensor near the exit area of the fusser may have the problem. Mostly the lever spring gets dislocated or broken.
Thanks.
I am having repeated paper jams in the rear door of y HP 4200. It occurs right when the paper hits the rollers to go into the outbin, and the paper stops and jams in the rear door area. I have to open...
It's been a while since I worked on a 4200. Will it print if you keep the back door open?
If yes, does it jam?
If yes, and it doesn't jam, replace the paper delivery assembly(RM1-0026-040CN)
7helpful
2answers
Defeito outbin full da empressora samsung 2550
The plastic paper guide where your paper exits the printer is stuck in the up position triggering the sensor. Push the plastic guide down and it should solve the problem
I have a kenmore elite model number 795. my ice dispencer only gives crushed ice even though its set to cube
1st i would remove all ice out of bin, clean outBIN with warm water under sink. put ice back in do not throw away for testing purposes. if worked then a cube may have been caught in bucket chopper improperly . if didnt change anything could be a bad crusher solenoid. in home service could run you 90-145 dollars depending where you live. if you do it yourself crusher dispenser solenoid will run about 30-50 DOLLARS. hope this helps
1helpful
3answers
My HP laserjet 1200 is making a terrible noise when printing - do you have to oil the rollers?
No Please don't oil any part of the printer, oiling may damage the complete printer first check if the nopise is coming from rear, Top, Front or side.
If noise is coming from Top than possibly top outbin roller are making noise.
If side tham may be toner cartridge or cartridge motor is making.
If noise is coming from rear than either fuser or the gear which rotates the fuser are making noise.
If noise is coming from from than Tray 2 pickup assembly or faulty tray is making noise possibly faulty registration assembly can also mak noise none of the part should be oiled only the faulty part should be replaced.
2answers
PJL
1- set tray 1 either to paper size letter or any
then paper type to ANY
2- set tray 2 to Letter and Plain
3- go to file - print - right click on printer- properties- device settings make sure you have the properties correct. ( letter size, any options must be listed here, duplex, stapler etc.. and set to on
Samsung ML-2550 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
