Aeg lavalogic 1610 (E5E) - Washing Machines
2 Related Answers
Mukesh Kumar
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Posted on May 06, 2009
rickyrt441
Richard Hale
  • 4399 Answers
SOURCE: The display of my AEG
Thanks for choosing FixYa and welcome. What all is the washer doing or not doing?
Posted on May 10, 2011
Lavalogic 1620 leak from rectangular hole at top of unit
is your inlet water pipe pointing straight down?i have read the instruction manual for this machine and it says to have the inlet water pipe turned 90 degrees to the left or right. is the rubber seal firmly in place? hope this helps..
Dec 04, 2013 | AEG Lavamat Lavalogic 1600 Front Load...
C5 is showing
C5 generally indicates a motor fault, specifically overheating. things that might make motors overheat are worn bearings and restricted ventilation
Mar 31, 2013 | AEG Lavamat Lavalogic 1600 Front Load...
Require a user manual for a LAVAMAT 1000 to download
Hello I need to number kushintës Lavalogic AEG 1600 washing machine
Feb 07, 2011 | AEG Lavamat Lavalogic 1600 Front Load...
AEG oko lavalogic 1820 Machine begun to make a noise like if drainning , and in the screen appeared the legend "error code EF3 please call your local service force" could not switch it off , so i...
Take the backside of, clean the water or moisture from the bottum of the machine, pluch it in and start, check for any leaks. This is a safety device that set in by any possible case of leaks.
Sep 14, 2010 | AEG Washing Machines
Lavalogic 1620 fails to come on - there is power to the machine - any idea what next to check kind regards
I also have problems with AEG Lavalogic 1600. It is caused by the control knob and the poor contacts. One service repair person fixed it and lasted 1 month. Then the problem reappeared. Now, I turn on the knob and the machine does not turn on, but I push lightly the button, not to a full path, just to cause a contact and it starts.
May 31, 2010 | AEG Lavamat Lavalogic 1600 Front Load...
VERY NOISEY WHEN SPINNING COULD IT BE THE BEARNINGS
The best way to check is to remove the belt, and spin the drum by hand.
If it feels rough or is rumbling, then the main bearings have failed.
Dec 15, 2009 | AEG Lavamat Lavalogic 1600 Front Load...
Error code C3
LOOK IN YOUR MANUAL...IT SHOULD HAVE A SOLUTION TO THIS CODE..JUST FOLLOW INSTRUCTIONS...BEST OF LUCK..
Jan 11, 2009 | AEG Lavamat Lavalogic 1600 Front Load...
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
Door not unlocking
open the filter door at bottom turn screw with coin , door should open ,
Oct 02, 2006 | AEG Lavamat Lavalogic 1600 Front Load...
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
