Question about Whirlpool Freezers
Whirlpool conquest fridge; freezer isn't working
I have a Whirlpool Conquest fridge, GS6SHAXKQ01 (8 years old). The freezer isn't working and everything is thawed. The icemaker works, but the ice is melting; the refrigerator side is working fine. A couple of days a go there was a sharp smell in the kitchen (the closest I can describe it is like a capacitor fried) - maybe that was something burning out?
Posted by maxhot6 on
David Emmel
    Sergeant:
  • 295 Answers
Https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Posted on Jan 02, 2018
5 Related Answers
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Posted on Jan 22, 2009
Anonymous
SOURCE: whirlpool upright freezer making buzzing noise and not working
I had a similar problem yesterday. I woke up and the freezer was not working anymore. It would make a buzzing noise and then it would click and shut off. I looked online for some possible solutions. Here is what I did:
I unplugged the fridge. I pulled it out and took off the cardboard backing. I used an air compressor to blow out all of the dust and dirt that had accumulated on the condenser coils. A shop-vac just wasn't powerful enough to pull out all of the dust/dirt. After that, I plugged it back in....and the same thing was happening. It would buzz, and then it would click off. I figured out that the "click" was coming from a starter relay (a small plastic piece attached to the big black compressor). I detached the plug from the relay and then detached the relay from the compressor. The relay was burned out. It turns out this is a common problem with the relay. I replaced the relay for $50 (from an appliance parts store) and put the whole thing back together in about 10 minutes.
I plugged the fridge back in and the compressor started, and now the freezer works better than other. I saved about $400 doing it myself, all in about one hour. And better yet, my wife was very impressed. Not bad for a doctor.
Posted on Jul 04, 2009
santange
  • 99 Answers
SOURCE: fisher and paykel e521t icing issue
should be a hose going down to drain pan, check it, could be plugged, or compressor on way out an controll not workin prop.
Posted on Jan 04, 2010
Anonymous
SOURCE: Samsung fridge/freezer model SRS73DTA doesnt freeze.
Hi I have the same problem,
did you get an answer to your question..?
Posted on Feb 02, 2010
Raz Mataz
  • 389 Answers
SOURCE: not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Posted on Apr 21, 2010
I have a samsung 1 year old fridge that wont get cold at all. the compressor, evap and condensor fans all run and i installed a schrader valve on low side to try to vacuum and charge with no luck. it
Compressor should rapidly bring pressure down from standing pressure to running pressure when switched on. If no change, compressor not pumping. Make sure the line tap valve isn't leaking, and the gas you used was correctly charged.
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
I don't have the model number. Fridge/freezer five years old with an electronic control panel on the freezer door. Freezer temp not showing, nor can it be adjusted. Freezer temp lowering, but appears to be...
Well, its good that it is still cooling, however since you cannot adjust the temps, you do still have a problem, and one that may include the unit fails to cool properly.
Oct 04, 2010 | Whirlpool Freezers
Gladiator fridge/freezer-freezer not cold enough, stays at 10 deg
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Dec 12, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Hello I own a whirlpool Fridge + Freezer.
Hi lewis,
This is very suspect if it blew straight away I would suspect the compressor going to earth, I am still not convinced with the comp after all ts ten year life is up, It could be something to do with the thermal overload on the comp if it has one.
The compressor does run for 12 hours but in that twelve hours does it reach temp? does it actually switch off on its normal routine?
where about in the uk are you?
Jun 29, 2009 | Freezers
Fridge Freezer is blowing out hot air, is this fixable and cheap to fix?
is this under warranty? not a year old? thermostat or low refrigierent in compressor.thermo replace price ok.comp refrig can be expensive. hope this helps
May 21, 2009 | Whirlpool Freezers
Whirlpool fridge freezer tripping the electric
PLEASE CALL PENINSULA ENGINEERING & SERVICES
9224699796 , BASED IN MUMBAI 24 HRS SERVICES 100 % JOB SATISFACTORY
Sep 03, 2008 | Freezers
Dandy 8.8 fridge not working but freezer does
freezer works but fridge wont cool
Aug 29, 2008 | Freezers
Freezers Logo
390 people viewed this question
Top Whirlpool Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
jasbo
jasbo
Dennis Boxerman
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
