Vertex Cd Vx-2200 Vx-2100 Series Programing Software Ce82 Logo
Question about Vertex Cd Vx-2200 Vx-2100 Series Programing Software Ce82
Vertex 2200 transmits but makes no sound
  • John L radiodude365 Dec 29, 2014
    It transmits no sound, like voice or does not receive any sounds, like voice messages
  • CRAZYCRAFT
    CRAZYCRAFT Nov 18, 2018
    Hi I have a vertex desctop reapeatr it is pluged in to a mixer bourd I unplugged a mic jack and pluged back in now I hear no voice on the radio pleas help asap
Marco De La Fuente Fernandini
    Habit-Forming:
  • 160 Answers
You mean NO Audio Transmit?
If there is No Audio at PTT Bad MIc Cord.
Change the Mic cord.
Posted on Dec 31, 2014
Mike Charette
    An expert that gotĀ 10 achievements.
    Genius:
  • Vertex Master
  • 1,847 Answers
This is where talk back comes in handy.
Posted on Jun 28, 2015
John L radiodude365
    Master:
  • Vertex Master
  • 570 Answers
Very likely transmit inhibit enabled. The red PTT light goes on, but nothing is actually transmitted. Or it is a bad microphone, or mic cord.
Posted on Dec 29, 2014
I bought a baofeng uv5r and want to link it to my work radio which is a vertex standard vx160u..I can transmit from the work radio to the baofeng but cant figure out how to transmit back to the vertex
First of all, technically, you can't use this radio to talk to anyone other than ham radio- that being said, if you want to proceed at your own risk. Ok, is your work radio an analog radio? Is it narrowband FM? Is it digital MOTOTRBO? Last two will make if difficult. Digital is impossible. Next, find out the exact transmit and receive frequencies for your radio. They may not be both the same if you have a radio 'repeater' your input frequency could be 5MHz higher than your receive frequency. And last- you need to know if your system has a "PL" tone (CTCSS, or DCS) subaudible tone that will break the squelch. So there are several variables that you will need your plant supervisor to relay to you. Good luck. You can probably get much of this info on line from radio reference.
I have 4 vertex VH-160 radios, two of them have stopped transmitting, all have been dowlaoded witht he same frequencies. Batteries are good. Whe transmit buton is pushed, the is one beep then nothing. ...
The VX 160's may have bad oscillators. It is not user repairable. The simple thing to check are the antennas. Vertex radios are very susceptible to broken antennas and will not transmit. This is true of Uhf and Vhf. Replace one and try it on all the radios. Never transmit without a antenna. It can cause the PA in the radios to fail.
Ftl2011 nao transmite
More information is needed to help you; On which frequency are you trying to transmit? The radio has its band limits set by regulations of different countries. If you're trying to transmit on a frequency that's outside the limits of what the radio is setup for, it won't transmit.
1helpful
Vertex VX4600. when the anntenna is connected and the radio is keyed it pulls the power supply low and the radio turns off. Without the antenna, the radio functions normally. Cable checks open to gro
Is your power supply large enough? It sounds more like too many amps are being drawn or the power supply has a problem. New power supplies are not as good as the "old" ones and develop some strange issues, like not enough power (amps) actually getting through. I assume heavy gauge wire. How many watts are you transmitting with?
My vertex vx-2100 receives but will not transmit
Hi Rich,
Here's the solution to your query: join yahoo group specific to your radio Make/Model, the team of experts will only be to pleased to assist you, plus you can have downloads, free.
I hope this sets you right.
Best regards,
Peter
Vertex ce82 on my laptop says ce92win power on radio trying to program vertex 2200 mobile radio
Hi Shawn,
The problem is on the screen for you to see.....
You need to downgrade your CE OS to Win CE82, else you r Vertex software won't work, but downgrading is futile, so unless you can get hold of a friends Pocket book PC running Win CE OS 82, you may have problems.
This is a Win CE Operating System fault rather than Vertex software fault.
You say laptop, Win CE OS is for the smaller Pocket Book PCs as far as I'm aware.
If you're running that OS on a laptop PC, that can cause you lots more problems.
I hope this answer clears up the issue a little.
Regards,
Peter
Top Vertex Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
