Question about Haier BC112G Wine Cooler
What does it mean when "LL" shows up in the temp light box? Also the wine fridge was very cold with condensation inside and out. We just got home from a week away and noticed a high whining sound as well.
Posted by myra on
katjordan
    Problem Solver:
  • 10 Answers
You may have had a power surge or outage while you were gone. The temp sensor may have failed or the control board may have failed. Either way, the code means that the temp in the frig is not the temp that it is set to be.
Posted on Dec 01, 2013
2 Related Answers
Anonymous
  • 750 Answers
SOURCE: Haier Wine Fridge problem
Hello bano24
Welcome to Fixya
My name is Huum,
You have a faulty cold control (temperature control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
Check the control for continuity.
And or need a hands on service tech to diagnose this fault
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Dec 31, 2008
Jacques Alexandre
  • 183 Answers
SOURCE: Wine temp on Haier wine
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
Posted on Dec 31, 2010
What does LL mean on the temp on the wine cooler?
It probably means "low level" ie the lowest level of cooling.
For a wine fridge this should be no cooler than 10 degC or 50 degF
Mar 29, 2017 | Ovens
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Uline wine fridge 2075-wcs not cold enough
Check condenser make sure it is clean then listen to see if condenser fan motor is running . if compressor is running cuntinuesly and other mentioned are ok it could be low on Freon
Nov 08, 2012 | U-Line Refrigerators
Bottles in candy wine cooler ccv 150bl are not cold enough even with thermostat is turned to cold is there any way to solve this
Check the condenser is clean, and the inside not iced up. Is there a fan inside? Check all is operating normally. When you say it is not cold enough, what temperature are you trying to reach? For keeping / storing wine, 8 to 10 c should be fine. For chilling before drinking, take the wine to a domestic fridge to get it to 4c
Apr 21, 2012 | Candy Refrigerators
Wine temp on Haier wine cooler BC112G went to LL, opened up and some champagnes frozen, other wines very cold, condensation all over door, how do you fix this error?
Dec 31, 2010 | Haier BC112G Wine Cooler
Light stays on. It was flashing LL for the lower
the first step is shutting it off for 24 hours with the door open to make sure there is not any ice on the evaporator. next, make sure the door seal is sealing properly. if neither of those are the culprit, you may need a new thermostat.
Nov 06, 2009 | Haier HVZ040ABH5S Stainless Steel Wine...
We got home from work yesterday and the refrigerator was HOT inside.
How to check stuff
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 10, 2009 | GE Profile PCF25PGW Side by Side...
Hello bano24
Welcome to Fixya
My name is Huum,
Dec 30, 2008 | Haier BC112G Wine Cooler
Haier BC112G Wine Cooler Logo
402 people viewed this question
Top Haier Furniture Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Dennis Boxerman
Are you a Haier Furniture Expert? Answer questions, earn points and help others
