Toys Logo
Question about Toys
Can two tracks be powered with the Lionel Trainmaster R 100 Watt transformer?
If so, what terminals do I connect to? I'm already connected to B & F for one track.
Posted by Bill on
  • edoptician Dec 04, 2013
    Reverse terminal 1 and terminal 2 Terminal 2 is the outside rail, terminal 1 is the center rail.
edoptician
    New Friend:
  • 22 Answers
Track 1 as you have it connected is terminals B-F. The second track would be terminals B-C. Connect post B to the outer rails Terminal 1 ? on your lockon. THis will give you 6-16 volts at the track.
Posted on Dec 04, 2013
5 Related Answers
Anonymous
SOURCE: Need help setting up Lionel North Pole Central
I had the same dilema and trains are not new to me. Look under the piece of straight track that has a notch in it for the wiring. There will be a clip to hold the wire and a piece of plactic that looks like a block. One either side of that is a metal tab that one end of the wiring slides over. Actually each piece of the Fastrack has one of these. Only one has a notch but you can notch any one.
MHC
Posted on Dec 04, 2009
Anonymous
  • 36 Answers
SOURCE: I have a z1000 transformer, at the controller
use some heatsink
Posted on Apr 06, 2010
Anonymous
  • 2299 Answers
SOURCE: I have lionel fasttrack 036
If you have a multi-meter then you can check the track to see if you are getting any power on the two track rails. If you are getting power, then check the remotes with the meter on ohms.
Posted on Nov 15, 2010
RyanFanMan
Ryan Nguyen
  • 342 Answers
SOURCE: 3 year old Lionel 4-4-2
you may have to use a Lionel transformer for this because some older trains worked on AC current not the DC current that this train uses
Posted on Jan 02, 2011
Anonymous
  • 10 Answers
SOURCE: No longer have manual for
See link below to PDF file with instructions to your transformer. It looks like you are correct with regards to the wiring with what I can see in the manual.
Hope this helps and good luck
www.lionellines.com/files/manuals/KW_Manual.pdf
Posted on Aug 04, 2011
1helpful
Wiring 1122 switches for crossover
Question is unclear. But if you want both switches to throw at the same time all you need to do is connect the 3 terminals on one switch with the matching terminals on the other switch. Run a wire from left to left, center to center and right to right. If the switches do not switch into the same track just reverse the right and left wires on one of the switches.
1helpful
Need wiring diagram for Lionel 313 Bascule Bridge
There are 5 terminals on the bridge number them from outside to inside 1,2,3,4,5
Terminal 1 gets connected to the outside rails on a V,Z,VW,orZW transformer terminal U. The control button a #96 push button gets connected between terminals 2 and 3. Terminal 3 also gets a wire from A or B on a V or Z or Bor C on a VW/ZW. Terminal 4 gets connected to the transformer terminal D. Terminal 5 gets a wire to the lockon on the black bridge frame. The bridge needs 3 sections of track on each end seperated from the rest of the track as a stopping section remove the center rail pin on this section, This forms the stopping sections at each end of the bridge.
Oct 14, 2013 • Toys
I am using a standard 80 watt transformer (not command control), but the rail sounds do not work on this unit at all. I have checked the on/off switch and played with the volume, but still no sounds. At...
Many of the MTH Protosounds 1 and 2 and Trainmaster will not work with the Lionel CW-80 electronic power source. The output waveform is so non-like sinusoidal. The electronic sound systems will not usually respond to this waveform and when they do, the sound will be garbled. Use another power source.
My new lionel train slows down on far side of the track
There is bad contact in the track connections. You can sand the track connection sites. Another method is to run another power wire to the other end of the track where the train slows down. Even better is 3 or 4 evenly spaced power wires from the transformer to the track.
2answers
Is lionel 40 watt transformer from toy train enough power to run a dual motor larger train engine it just lites up and sputters
It would depend on what engine you're trying to run. The 40 watt transformer's circuit breaker will trip off if you put too large of an electrical load on it. If the engine light stays on while it sputters, the track or the engine's motor and electrical pick-ups may need cleaning. Older engines that haven't been run for a while can get stiff. Your engine may need some lubrication.
1helpful
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
No voltage on the red terminal to power up the track. open'd up unit looking for broken on loose connection but found none.
Check the primary and secondary windings with an Ohm meter to determine if the transformer is bad. You should get measurable resistance through both coils. Hope this helps
1helpful
Lionel Trainmaster KW 190 Watt Transformer
The Lionel postwar 190watt transformer is an excellent power supply for trains. If one or more of the binding posts are loose ("U,A,B,C,D" Terminals") you will need to replace the binding post, use a T-159 replacement Binding Post. The original posts are soldered and crimped on.
The T-159 replacement binding post is bolted on. UNPLUG THE TRANSFORMER Carefully pull/pry up the handles and remove them remove the 4 Philips screws on the top, lift off the case top, the binding posts stay with the body of the KW.
Remove the loose bindings post one at a time as needed. Be sure to get any wire reattached. Reverse the procedure to reassemble.
Open Questions:
Top Toys Experts
Marvin
Marvin
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Toy Expert? Answer questions, earn points and help others
