Question about Canon DC210 DVD Camcorder
Initiation of DVD
How to do initiation of a finalized Dvd in Camcorder DC301
Posted by Aziz Bava on
5 Related Answers
Anonymous
SOURCE: Unable to Finalize Disc/Finalize Option Blacked Out
After spending some time with Canon at 1-800-828-4040 I have found out that there is one small but crucial step missing in their instruction manual on Finalizing the disc. Take battery out and power the camera with the cord plugged into wall socket. Turn camera to the on position and let DVD normalize then when it stops move the on switch downward into the play position. With the viewing window upen you will see thumbnails of the pictures that are on the DVD and a small green light will come on opposite play on the camera. Push function and a menu will come on that says disc operations at the top AT THIS POINT PUSH THE JOYSTICK TO THE RIGHT and you will notice the light move from the right side of the viewing window to the center. Now with the joystick scroll downward until FINALIZE is highlighted even though it is in white, push inward on the set button on joystick and you will get a screen giving you information about how long it will take to finalize and it will ask you if you want to finalize yes or no. Choose yes and it will turn yellow or orangish and will start finalizing. You will also get a progress bar at the bottom as it finalizes. When it is finished finalizing you will note that FINALIZE in the menu has turned black. The one step about pushing the joystick to the right just as soon as you get the menu is crucial. Hope this will spare a lot of people a lot of frustration. I was almost ready to send mine back to the company or junk it.
Forrest
Posted on May 19, 2008
Anonymous
SOURCE: canot finalize dvd
I am having canon dc 210 digital camcorder, i cannot able to
view my dvd in my computer or in dvd player, why i dont know i tried my best, is any software is required to view in the computer .if say yes, please mail me the software immidiatly and oblige. with regards.my email is. [email protected]
Posted on Jul 05, 2008
Anonymous
  • 3 Answers
SOURCE: Canon DC220 DVD Finalization problem
You have to plug the camera into the wall charger in order to finalize. I was having the same problem. Once finalized, I transferred the disk to the PC. You need DVD decrypter software in order to view the videos on the disk. Canon does not supply this. Canon recommended that I use one of several free downloads. They said download "DVD Decrypter" which I downloaded. Type DVD Decrypter into Google search and you will find it. It will rip it and download it to your computer. I then viewed the video with Windows Media. It works fine.
Posted on Nov 19, 2008
Anonymous
  • 3 Answers
SOURCE: canon dvd camcorder dc220 recorded dvd play laptop for vista
I have Vista. I used a free download "DVD Decrypter" and it converted the files. I then just used Window's Media to view them.
Anonymous
SOURCE: canon dvd camcorder DC210
Ok, Guest @ solution #1 and #3 solved this for me.
Step 1. remove battery pack.
Step 2. Plug in to outlet.
Step 3. Insert desired disc.
Step 4. Toggle down on the "mode" lever for "Play-back" mode.
Step 5. Press "function"
Step 6. Scroll to and select "menu"
Step 7. Scroll to and select "disc options"
Step 8. Scroll to and select "Finalize"
Step 9. Scroll to and select "Yes"
Follow prompts from there.
This worked for me.
Thank you all!!!
Posted on Mar 24, 2009
Do you have to initialize your camcorder before you start?
You do have to initialize the DVD-R before recording into it and you have to finalize it when it is full (or whenever you wish to) in order to view it on DVD players.
Thanks for using Fixya!
Jun 01, 2011 | Canon DC210 DVD Camcorder
Can you initialize a DVD-RW after you have recorded on it?
hi its geoff
yes you can. i dose say that no more recording can be done after the disc is finalized (thats true, you first have to unfinalize the cd to write more files on it.but you can initialize the disk at any time but you lose the recorded content(it frormats the disk) then you can use the disk over and over again. remember finalizing and unfinalizing requires you to plug the mains charger into the camcorder it assumes theres not enough power in the battery to do the job and will need the mains every time.but initializing only requires sufficient battery power .
Aug 10, 2010 | Canon DC210 DVD Camcorder
Initialize the discs then record...but then it still wont play on the computer/dvd player Canon camcorder dc210
I have a Samsung recorder, and it requires you to "finalize" the disc before it will play on another unit. Check your manual for specifics, or look in your menu for the "finalize disk" option. Hope this helps...
Mar 14, 2010 | Canon DC210 DVD Camcorder
MY DVD R DISC WILL NOT PAY IN MY DVD PLAYER - I HAVE A SONY DVD CAMCORDER BUT THE DISC WILL NOT PLAY ON MY DVD PLAYER
Please finalize recorded dvd disc in camcorder then it can be playback in any other dvd player.
Disc finalize option is available in camcorder disc menu.
Thanks.
Sep 09, 2009 | Sony Handycam DCR-DVD403 DVD Camcorder
Did not initialize Canon DC220
try fully charging it and finalizing the disk then try it on your computer
only if your useing a -RW DVD
Apr 22, 2009 | Canon DC210 DVD Camcorder
Can not finalize
Hi, Initially I had the same problem with the finalization process. But then i took off the battery pack and connected to the mains and immediately when i switched on the camcorder again, the ' Finalize ' button was highlighted i.e enabled. I continued with the finalization process and everything was fine. Was able to playback the mini dvd on a very cheap dvd player and also on a computer.
Also be sure to put the camcorder on play mode by sliding down the switch button to mode. You immediately notice that a little green button near play will light up
Jul 15, 2008 | Canon DC210 DVD Camcorder
Cannot intialize/finalize mini-DVD in Canon DC210
The way to get it to finalize is like this:
1. turn it on
2. use cord.
3.move the on buttom to mode. it will show the recordings.
4. select a recording
5.press function butom. it will up bring several choices among "menu"
6. slect menu
7. it will give you all the chioces you need to title, finailize, protect and all needed to view the dvd
Any questions,
let me know.
OL
Jul 13, 2008 | Canon DC210 DVD Camcorder
Can't Initialize/Finalize
I dont have a solution, but the same thing is happening to me.
I've recently had an operation and I had before and after pictures,
And because finalize didnt show up I tried initilizing it and all the images got deleted!
Message me back if you find out how to do it!
Thanks!
x
x
Sep 10, 2007 | Canon DC210 DVD Camcorder
Canon DC210 DVD Camcorder Logo
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
