Question about Jacuzzi Signa 6 Whirlpool JAC-B540...
I have and h24000 jacuzzi older model it is flashing fl can someone help
1 Related Answer
Alan
  • 80 Answers
SOURCE: jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Posted on Sep 28, 2009
My jacuzzi is flashing FL1 and the heater isnt coming on
FL is a "flow" issue. Check the filter to make sure it is clean. Start by removing it from the tub and see if that solves the error. The next item to check is the gate valves to make sure they are open all the way. There are usually one on either side of the pump and control box.
Rod
US Parts Center
Aug 19, 2013 | Jacuzzi Home
Why is it flashing fl and why is watercod
FL is used by some for a water flow problem. If you have the error then these are a few things to check.
  • Check for a dirty filter.
  • Check your gate valves on each side of the pump
  • Make sure they are fully open
  • Check the pressure switch to ensure it is operational
if you do not have enough water flow in the system it will not turn on the heater. The heater not being on will obviously allow the tub water to go cold.
Rod
US Parts Center
888-521-6183
Nov 14, 2011 | Jacuzzi Home
I have a Jacuzzi Z 145 spa. I was constantly getting an FL error. Purchased a new switch, put it on and when I turn the spa on I immediately get a circuit blow. What could be causing this problem?
Its possible your heater has a ground fault. If the old pressure sw was giving the FL code the system would not send power to the heater. Now with the new sw working power is being sent to the heater.
Oct 23, 2010 | Jacuzzi Pool & Spa
My jacuzzie starts and stops wen it is runing i have a fl code
FL is a flow error, you may not have enough water going over filter housing. Jets are they open?
is your heater fitted with a pressure switch? when on FL locate pressure switch wheel and turn all the way anti clockwise until it stops then slowly wind back until you hear a click reset in control box - you have reset pressure switch.
If you have done this and still show FL or heater is not fitted with pressure switch then your LOW speed on pump maybe faulty (new pump) or heater maybe scaled up with lime scale and reducing water flow through heater - remove scale from heater, flush through and increase ANTI-SCALE
Adam Miller
Service Manager, Canadian Spa Company, UK
Aug 07, 2010 | Jacuzzi Pool & Spa
Jacuzzi hot tub model J-300 series with an FL-1 code. I have shut off power at box and restarted a couple of times and the circulation pump reset. Now the reset won't happen. Both pumps still operate and I...
A flashing “FL1” display means the flow switch is
malfunctioning open, the filter cartridge is excessively
dirty or an “air lock” condition has occurred at the
circulation pump intake.
Jan 06, 2010 | Jacuzzi Signa 6 Whirlpool JAC-B540...
I have a Jacuzzi spa that has a FL on the read out.
the FL code is usually an insufficient flow fault. you may have a dirty filter or a faulty flow switch/sensor.
Dec 27, 2009 | Pool & Spa
Jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sep 24, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Connect a FL-20, FL-36, FL-40 or FL-50 dedicated external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-750 Zoom. FL-CB02 Hot Shoe to TTL Cable -this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Jacuzzi Signa 6 Whirlpool  JAC-B540... Logo
122 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
