Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-65857 Tv will not turn on
When I turn on my mitsubishi WD-65857 it turns itself off immediately
5 Related Answers
Anonymous
SOURCE: My TV turned itself off and it keeps doing so everytime I turn it on
disconet keybord ,use remete only
Posted on Jun 26, 2007
premtech
William Rayburn
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Posted on Dec 18, 2007
voodoomox
marlon john madrid
  • 1689 Answers
SOURCE: mitsubishi wd 52825 tv It wont
it is common for a cuircit board called the dm(digital module) to go bad in these units. this set has a keyboard lockout feature.
Press menu for 10 seconds on front panel. if that does not release control then u more than likely have a problem with dm module. there are several bullitens about this and several things a tech can do to repair this set.
by willtab
just a head's up, getting this repaied my cost a little big.
good luck
Posted on Jul 27, 2008
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: cannot turn tv on
Check power supplly make sure its not the fault in wht this will not turn on.
Unplug tv from wall wait 30 secounds and plug back in.
If that does not work you will need to have someone look at the powersupply.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jul 01, 2009
My mitsubishi wd-65c8 has a flashing green light.. I have replaced the capacitors on the DM board and the same is happening.. what else could be the...
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Jan 23, 2011 | Mitsubishi WD-65C8 65 in. LCD HDTV
Mitsubishi DLP TV model WD-65100. Power not ON
What about Lamp Fan if it is defective lamp will not turn on and if Ballast Board is not working then Lamp itself will not power on. Encompass has parts for this TV 1-800-638-3328
Feb 09, 2010 | Televison & Video
Turns itself off immediatley after turned on
mitsubishi projection TV turns off by itself after a couple minuts of viewing TV?
WD-62527
Apr 28, 2009 | Mitsubishi TS-5545 55" Rear Projection...
Mitsubishi ws 65857 powers off
Your set is the V17 chassis it doesnt have a DM board, your problem is most likely centerd on the main Circuit board .
Jul 24, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi WS 65513 turns itself off
Probable four bad caps in DM module = 1000mf/25v
Common repair for qualified Mits tech...........T.
Nov 11, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
59 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
