Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Fisker & Paykel ds603i drawer removal - Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
3 Related Answers
Anonymous
  • 19 Answers
SOURCE: how do you remove the drawers on a fisher &
Open the drawer, on both sides, near the front there is a small circulat pin, with a slot in the middle, grab the middle with a pliers, and pull straight out, with this out, the square button in front of the hole will push in, and slide it slightly back, then the drawer will slide out, and you can lift it off the rails.
Posted on Dec 03, 2009
Testimonial: "thanks for the info it pionted me in rite direction"
Sam
  • 3247 Answers
SOURCE: need to remove front drawer panel
There are two plastic bolts on each side of the dishwasher drawer holding the front cover. Get a plier to pull these out but make sure the cover is supported so that it does not fall down.
see installation manual page 7. The location of the plastic screws is shown in insert diagram of notation 6. This is for a later model but yours should be similar.
Hope this helps. Wonder why you want to remove the front cover?
Posted on Jul 08, 2010
Matthew Cross
  • 88 Answers
SOURCE: My single Fisher & Paykel
Yes ,you may be able to restore function by completely drying the area and PC board located under drawer.Use a hair dryer.
However , you will still have a leak and the problem will return.Usually the leak is drawer lid not closing properly. Suspect lid actuators have failed.Very common.Or some kind of obstruction.The drawer can be removed easily by removing 2 large plastic scews at drawer front.If lid actuators have never been replaced go ahead and do that.It is normal for other drawer to work fine.
Hope this helps you
Posted on Aug 16, 2011
F&P DS603I Leaking with no faults or alarms
Hello Steve, Just saw your enquiry. Not sure if you have found the source of the problem by now. You are in F&P teritorry so should not be difficult to fix. I have a double drawer DD601 for nearly 10 years and I keep it running - recently had to replace some wires on the lid seal system on one drawer as these had cracked with age.
I don't have much experience with the single drawer units But it is very unsual not to have alarm F1 given the type of leak you are noticing. I am leaning towards the leak coming from the plumbing outside the dishwasher. Inlet hose or outlet hose under kitchen bench. You can check the seals and lid motor in diagnostic mode but this is not for the faint hearted as one can damage components if wrong command is given in particular heater and pump rotor. First thing to check is whether there is no physical damage to the seal. Slide your open palm along the housing inside with drawer fully extended. If you notice any cuts or undulations in the rubber then there is a problem with seal and needs replacing. Try to slowly pull out the drawer after starting the dishwasher. It should not come out easily if the seal motors are working. Not sure how easy it is to take the drawer out with Integrated unit. If you can take the drawer out to check water collection on base then that would tell you something. But make sure the mains power is off first. Send me a post. Sam the ozzie.
Jul 01, 2013 | Fisher and Paykel Dishwashers
Fisher & Paykel DD601v2 dishwasher
here's the manual..
i did not read thru the whole thing but there are quite a few removal items that i'm sure will lead you to drawer removal.
Hope this helps you.
https://www.scribd.com/doc/6462163/DD601V2-Manual
Jan 22, 2018 | Fisher and Paykel Dishwashers
My single Fisher & Paykel dishwasher drawer DS603I (Integrated Panel) turns on by itself even after turning off the light switch that controls both units that sit on opposite sides of the sink. The...
Hope this helps you
Aug 16, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
How do you remove the drawers on a fisher & paykel 2 drawer dishwasher please
Nov 28, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
My DS603I leaks the rinse agent. How do I check
I thought mine did, too. But that's the next dose, ready for the next load.
Jul 24, 2009 | Fisher and Paykel DS605I Built-in...
My fisher paykel nautlis dishwaher display error code F1
What is the Model #? If both drawers, if a double, display F1 and won't shut-up then the flood switch is tripped and you have to unplug it to keep it from beeping and the drain motor running. The causes for the F1 fault can be numerous but not excluding bad lid lifts, broken link support, cracked drain line and wrong soap. Call F/P
Jul 19, 2009 | Fisher DS603W / DS603B / DS603I Dishwasher
Fisher Paykel F1 is blinking on both drawers - how do I resolve this without calling a service tech?
f1 is a fload code the bottom drawer has to come out and dry up the water make sure the power is off
Jul 13, 2009 | Fisher DS603W / DS603B / DS603I Dishwasher
Dishwasher error
The error was a flood fault, water was not draining from either of the drawere, I removed the bottom drawer, dried drip pan and used hairdryer to dry fault sensor, the dishwasher then reset itself and works fine.
Dec 31, 2008 | Fisher DS603W / DS603B / DS603I Dishwasher
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
126 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
