Question about Toshiba Satellite® A215-S4807 PC Notebook
Toshiba A215 palm rest needs replaced - Toshiba Satellite® A215-S4807 PC Notebook
1 Related Answer
Anonymous
  • 2600 Answers
SOURCE: How can I replace the cracked palm rest for
Here is the service manual, it will explain the disassembly procedure to you. Just keep track of the screws, they are all different sizes. The case of the M45 is labeled with the screw sizes so you don't get them confused. It is not a difficult job, just take your time. When the link comes up, the page numbers are on the bottom.
http://www.irisvista.com/tech/laptops/ToshibaM45/Satellite_M45_disassembly_1.htm
Posted on Nov 07, 2009
How do you replace an inverter board on a Toshiba A215-S5818
have a look at this video it will show you how to open up the LCD screen and from there you can replace the inverter board
https://www.youtube.com/watch?v=zz9zdlktONM
Feb 28, 2015 | Toshiba Satellite A215-S5818 Notebook
Replace the keyboard on my toshiba l505d still dont work
Make sure the connector from the keyboard to the Motherboard is seated properly.
If reseating this cable does not resolve then follow the cable of the keyboard, does this lead to a small chip on the palm rest?
If so I would try replacing the palm rest as the keyboard chip indicated this is where the "brains" of the keyboard are.
If the is no ship it is most likely on the motherboard and may mean a replacement.
reagrds,
Mike
Oct 11, 2012 | Toshiba Satellite L505D-S6957 WXGA HD...
Computer on....screen black
if there is no video, it's best to rest with an external monitor, if it works, then you need to replace the LCD screen
Feb 02, 2011 | Toshiba Satellite A215-S4747 Notebook
Toshiba a215-s5837 problem, ac light only flashes
You may have a bad battery. Many times laptops will not work if the battery is faulty. The first step would be to replace the battery with a new one.
Second Step: If the battery is working, then you may have a faulty AC power supply. It may be enough power being brought to power up the LCD light, but not the computer.
Third Step: Yoru mother board circuitry could be bad in the sense that some circuits are broken or the power conduit is not supplying the power to the rest of the circuits on the board.
If you are not a professional and able to troubleshoot in this manner after testing the batter and AC power supply, then I would suggest taking the laptop to a store for them to test the circuitry flow of the mother board.
Dec 30, 2009 | Toshiba Satellite A215-S5837 Notebook
Nov 07, 2009 | Toshiba Satellite M45-S265 Notebook
HDD pasword requested at startup don't know it
I believe I spoke with you during a chat session.....there may be one possibility to try and that is to disconnect the cmos or (RTC) battery for at least 45 seconds. Then reconnect....go into the BIOS and find the title "Set System defaults" maybe on the F10 page. Save and Reboot. See if this resets everything for you. The only stickler is that I believe the rtc battery on those is under the palm rest, so the laptop will have to be dsassembled. I have a service guide for the P205, that shows the steps. Good luck,
http://www.irisvista.com/tech/laptops/toshiba-satellite-p205/removing-motherboard-1.htm
Oct 26, 2009 | Toshiba Satellite A215-S4747 Notebook
Need Satellite recovery cd
Yes my friend. Toshiba recovery cd cant be downloaded online. U need to purchase one from toshiba. Or if you want, you can purchase a retail version of windows then download the toshiba drivers from support.toshiba.com
Oct 05, 2008 | Toshiba Satellite A215-S4747 Notebook
Reset
It will be on the main board of laptop. You need to open the base and keyboard of laptop. Careful
May 21, 2008 | Toshiba Satellite A215-S5822 Laptop
Changing touchpads
In theory it would be possible, I can't tell by the documentation whether the touchpad is a seperate peace from the palm rest or not. Most laptops either build it into the palm rest which would not work for you, or the cable might be the wrong adapter/ too short etc.
Apr 22, 2008 | Computers & Internet
Toshiba Satellite® A215-S4807 PC Notebook Logo
19 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
