I am using the composite inputs, comcast cable source. This picture is too big, but the option to adjust the zoom is greyed out and not available. But as I am watching football, the scores in the left corner are cut off - I can see the score, but not the team. And this is on both HD and normal channels. Any help would be appreciated.
SOURCE: I have a comcast Motorola HD capable cable box
Here sounds like your override setting on cable box needs to be set.
Here is how to fix that-
1. On remote push the button at the top that says CBL or Cable.
2. On remote push power button.
3. On the remote push the menu button.
This should bring up an internal menu called user settings.
4 Use the remote to scroll down to 4:3 OVERRIDE and use the LEFT or RIGHT arrow keys on the remote to change the value to 480i and see if this clears up your problem. If not repeat and change the setting to 480p and one of these settings should fix your problem.
Good Luck and please rate this solution.
SOURCE: how can I have a full view of a hd station?..
If you have to use the "ASPECT" button on the remote, set the screen to "JUST" it gives you full screen without "morphing" the picture. If you are using HD cable, SAT, Or FIOS, check the main settings menu in the cable/sat/fios box. make sure its 16 x 9 or "Full" If you still have an issue, post a comment with the details of products connected to your TV. Makes and models and I will help you further. Hope this helps.
SOURCE: TH-42px75u Panasonic. The picture zoom
I have the same problem when i was watching the movie called ''Dilemma" but i still have no problems with other movies on dvds! it sucks! :(
And to clarify, the Aspect button on the remote does nothing, either.
