LG 37LP1D 37 in. LCD Television Logo
Question about LG 37LP1D 37 in. LCD Television
Lg tv auto tune will not tune tv channels - LG 37LP1D 37 in. LCD Television
5 Related Answers
Anonymous
SOURCE: Unable to tune my LG Electronics Digital TV (Model 37LC2d-ec) to receive digital channels (have tried auto and manual program). TV will only receive basic standard channels. TV bought in Uk - now livi
My LG plasma TV 50pc3d when power-on only see vertical bars. what 's going on. please help. Thank you
Posted on Jul 22, 2009
omaharox
Mike
  • 166 Answers
SOURCE: my LG tv wont tune all digital channels? im
Tv may need a firmware update or the Ch. is blocked in the Ch.menu.
Give LG a call @ 1 800 243-0000 they can give you more details.
Posted on Jan 20, 2010
LG help guy
  • 112 Answers
SOURCE: i have a lg 52lg50 lcd tv,everytime i turn tv back
This memory loss issue sounds like a problem with the main board inside the TV. The channel memory should not erase after a power cycle.
You are probably loosing other custom programming like your Display and Audio settings. That is if you had modified something in these menus.
You may want to check to see if this is also happening by making a change in like the Display menu, and then turn the unit off and back on.
The TV has a one year warranty on parts and labor.
Posted on May 21, 2010
Anonymous
  • 1779 Answers
SOURCE: TV has lost channel 3-1. Running auto tuning
Un-plug the set fir 10 minutes then run Auto tuning again, let me know.?
Posted on Dec 24, 2010
Anonymous
  • 635 Answers
SOURCE: New LG 32LD350 - Allowed TV to auto-program
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Posted on Mar 11, 2011
2answers
How do I channel scan for antenna with blackweb remote and a lg tv
Go into the tellys setup menu and select update channels then go to auto and it will find all the local stations.
I m having a problem with lg led le5300 26'' it is not catching any signal it has stopped playing any channel i have tried auto tuning so many times but no channel found.
Make sure your cable/antennae connection is OK and you're getting signal from over there by connecting another (working) tv set to it.
How do I reconfigure an LG 32LY560H from Commercial setup to auto tune for use in personal residence?
possible that you need to have cable to do this, you might only have 6 digital channels, without cable
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
regards
shaun
1helpful
2answers
All channels permanently deleted accidently, can I restore them
Auto tune the channels as found in the manual
  1. On your remote, press Menu.
  2. select Channel and press OK on your remote.
  3. select Auto Tuning and press OK on your remote.
  4. select Yes and press OK on your remote.
1helpful
I have a LG 32ld333h tv it won't auto tune and doesn't have a add/delete how do i get it to program channels
You sir have a hospitality tv used only in hotels and motels proidium tv type that needs a master remote or call best buy to reset to consumer type tv from commer
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
Marvin
Marvin
Muzahura Frank
