I'm not sure what you mean by a "zippy tie", but if your machine works and the sound is just annoying, I suggest you leave it alone. Chances are it will "fix itself" by wearing down the part more and more until it's too small to make a rubbing noise.
Also, double check all pockets from now on for unwanted bits in your clothes!
Good Luck.
SOURCE: Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
SOURCE: Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
SOURCE: i cant get the filter out of my washing machine help please
Sometimes a bigger object might block the filter knob, and make it impossible to screw out. Then the only way is to remove the end of the sump hose attached to the filter and remove the stuck object.
(In my filter this object was an Umbraco key) :-)
SOURCE: LG WM2355C water leaking under machine after washing finished.
I had this same problem and it was not the supply connections or filters! Under the machine is a rubber bellows. The bellows had sprung a leak. The part was about $10 from Sears and I repaired it in about 30 minutes. The machine is heavy so be careful. Get a friend to make sure the machine won't rock or tip when you're making the repair.
