Aiwa F2000 20" TV Logo
Question about Aiwa F2000 20" TV
TV is making loud whistling noise
Where my input connections are on the back when I put pressure on them the whistling stops. When I take my hand off them though, the whistling starts right back up again. What is causing this high pitch whistling noise, and how can I get it to stop? My TV was bought brand new in 2005 and it's worked fine with no problems until now. I don't have the money to get it repaired. The one repair place I know of in town often charges as much as it would cost for a new TV of the same size and spec, and I just don't have the money. Any realistic suggestions?
Posted by Michael Dugan on
  • Michael Dugan
    Michael Dugan Dec 05, 2013
    I've switched the cables around and the whistling still persists. I think it may be a flyback problem. I'm really hoping it isn't, because if it is, I'll most likey have to get a new TV set, and right now that means I'll be without a TV for quite a while.
nhpickles9
    New Friend:
  • 27 Answers
If you have a spare cable set, try using this in place of the existing one. Is it only one of your inputs that is doing this? If you have 2 inputs that are connected, first try switching the cables. If this doesn't fix it then it is either a problem with the tv or the input device. If the problem moves to the other input then you need to replace the cable. If switching cables doesn't work, switch to a different input. If this fixes the problem then there is an issue with the input on your tv. If neither of these fixes the problem then it is most likely a problem with your device.
Most likely there will be a problem with your cable connecting the device to the tv or with the connection between the cable and the input. If you think that it is a problem with the tv (ie. the female input socket) then I suggest getting it repaired (expensive I know) or you might be able to get a friend who is good with electronics to take a look at the connection.
Posted on Nov 30, 2013
1helpful
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Why does my electric pressure cooker make a loud whisting noise
It seems pressure valve is defective and not holding pressure , ((( Do not attampt to repair it your self , very dangerous )) contact manfacture for authorised service centre if there is any ,most of them ar not reapirable and they are one time deal
Engine is whistling loudly, and stops if i remove
I would have the converter checked for back pressure. if it is plugged it can cause excessive Engine pressure. if it is not plugged then you have excessive blow by or a malfunctioning PCV system it sounds like.
Loud whistling noise coming from tv speakers
a couple of things could make the tv chassis whistle
1 coud be dry solder joint probably on power capacitors
2 IF your tv has tube the board on the back could be making the noise its to do with the yoke on the way out!
Loud whistling noise when travelling at higher speeds (ie above 50mph)
I had a problem with a whistling car after 50 mph and it turned out to be the front window gasket. I put silicone on the trim and problem solved.
2answers
Loud whistle noise
Check your power steering fluid reservoir.
5helpful
Pcv valve location
volvo s80 y reg 2.4 runs ok little bit lumpy tickoover when warm but very loud whistling noise take dipstick it stops but very big suction from tube not pressure it is not breather box under manifold
2answers
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Top Aiwa Televison & Video Experts
Colin Stickland
Colin Stickland
Mike
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
