I have 2 problems with my Oven any help would be appreciated. When the oven is put into broil and hits 500 degrees inside it immediately switches to Self-Clean mode and the CPU locks the door with the food inside. You have to unplug it and wait 10 mins to be able to open the door again. The second is the oven will work at 350+ temp fine for an hour, then after an hour the temp drops to 300 degrees and wont go to displayed temp. Even if you raise the temp to 475 degrees it will only go up to 320 degrees. After you turn off the oven for an hour and it cools down you can use it again at 350-425 degrees for the first hour then it happens again. Any insights would be appreciated! I do own a ohm meter and know how to use it. :)
Seems the thermostat is malfunctioning...thus when baking at 500..thats quite high...it keeps getting hotter past that point to where the oven thinks its in self cleaning mode. Also seems like the problem because when it cools down your allowed to use it again. There is no way to test it with an ohmmeter. Just remove and replace.
Testimonial: "Thanks! Ill buy the part and try it"
SOURCE: The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition
Check/Repair
Digit Failure Code2
F1
Analog to Digital Failure
Disconnect for 30 seconds - if display reappears - replace control board
F1
Safety flip flop
Replace board
F1
Shorted keypad
Replace keypad
F3
Oven temperature sensor opened
Replace oven temperature sensor
F2
Oven temperature sensor shorted
F3
Oven too hot
F3
Clean temp too hot
F5
Check door/latch switch
Replace switch if defective
SOURCE: Whirlpool Accubake oven super capacity series 465
In an attempt to self clean my oven, I pushed the auto clean button and then pressed start. Instead, nothing happened, but now have a message on the panel reading E1on the left side of panel and -F5- on the right side of panel. I am unable to clear it or operate the oven now.
SOURCE: Whirlpool self cleaning oven, Super capacity 465, door will not close
I had the same FSE error which the whirpool web site advises that you will need to schedule a service appt to fix. Instead I leaded against the door while initiating the cleaning cycle and the door locks and oven cleans fine.
SOURCE: Oven Door Lock
We have a Jenn-Aire self cleaning oven. The cleaning latch would only open if BOTH knobs for the cleaned oven are set to cleaning. Then the latch opened right away.
I unplugged the oven and it cleared the code and was able to self clean the oven.
Oh and there are no error codes ever on the Board Display
