Question about Honeywell Programmable Thermostat Heater
Home Thermostat reads low batt
Just replaced batteries in thermostat but still reads low batt
Posted by Willy Velarde on
Brandon Berry
  • 407 Answers
I have ran into this problem before. I have actually had low batteries I thought were good too ha! I have had to actually reset the stat to get the low battery to stop flashing. There are multiple ways to reset the thermostats, depending on model, but removing the batteries and waiting has worked, along with actually having a reset button somewhere on the stat. Hope this helps!
Posted on Dec 08, 2013
My Honeywell thermostat still says batt low even after I changed the batteries.
Off position then reverse batteries polarities and wait 5 sec. Then place new batteries back to normal position.
Oct 11, 2018 | Honeywell Heating & Cooling
Thermostat display reads lo batt replaced batt still reads lo batt
Suggest have battery tested.
Most thermostats cost more to repair than to simply replace them.
Feb 04, 2018 | Heating & Cooling
Honeywell thermostat 8000 series- some of the buttons on the screen are not working. Replaced the batteries-still no fix. Read that there is a 3 volt battery also. Do you know where this is located?
Base on my experience. It's not fixable. Better just buy a new one. Don't has to be Honey Well brand. You can buy
any brand from Lowes or Home depot. It's compatible.
Good luck and enjoy
Mai Lor
Oct 18, 2017 | Honeywell Heating & Cooling
Battery icon lit on dash
The batt. may be not good. Take to most any parts place, they usually will
check the batt. condition for free,of course if bad will try to sell you a new
one.
May 14, 2012 | 1995 Ford Explorer
Bush -Audio-photo-video MP3 player. Is there a removable battery in this? it will not take a charge, after charg it reads low battery, help!!
yes there is a built in batt it will need to be replaced by a service tech most mobile phone repair shops replace mp3 batts
Mar 01, 2011 | Audio Players & Recorders
Everytime i replace the battery in my thermostat it says low battery
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can't find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Sep 22, 2010 | Honeywell Programmable Thermostat Heater
Even after replacing the battery, the programmable Honeywell thermostat still shows "Low Batt."
Turn control to off. Remove the batteries for at least one hour. If the display message still reads "bat lo", leave control off, batteries out, and disconnect the red wire on back and wait another hour. Reconnect red wire, put new batteries in and turn system on. It's like a reboot.
Jan 26, 2010 | Honeywell Programmable Thermostat Heater
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate batteries, turned the correct way. Cleaned off the battery terminals and still have replace battery...
Thermostat problem; Honeywell chronotherm lll ' Low Batt. indicator Keeps blinking after Batteries replace. I chk'd batt. with elect. volt ntr. Was told to pull batt. and change ends with them , letthem stay reversed for 5-10 sec. then put them back in right order,and replace thermostat. No success!
Anyone have any answers
Nov 12, 2009 | Honeywell Power Humidifier: Furnace...
Batt Lo Displayed. I replaced with new batteries. The display still reads Batt Lo and I cannot changed temperature, etc.
sometimes you can bend out the battery holders to allow more tention on the batteries but thats only a temporary repair. a new thermostat is needed
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
I HAVE A HUNTER PROGRAMABLE THERMOSTAT AND CAN'T REMEMBER WHERE I CHANGE THE BATTERIES, ITS READING "LOW BATT" PLEASE HELP, THANKS
Pull the unit face straight out and away from yhe wall plate. It plugs into several contact pins so rock genttly if you do. Good Luck, Ned.
Sep 28, 2009 | Heating & Cooling
Heating & Cooling Logo
542 people viewed this question
Top Honeywell Heating & Cooling Experts
Paul Carew
Sean
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
