I tried all default passwords and user names and still cant open default page, i tied also to manually restart router but still cant open setup page.
SOURCE: how to change router default name and password
you can't change the default name...that is always left blank, but you can change the password.
Access the user interface & click on Administration. It should automatically be in the Management section at this point.
Enter your desired password in the Router Password field.
Re-enter to confirm the password in the next field.
Click on Save Settings.
For more information on working with your router, you can access the User Guide provided by LinkSys:
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&pagename=Linksys%2FCommon%2FVisitorWrapper&cid=1166859837401&displaypage=download
SOURCE: hi please help
tell me when you open the page they ask some of user name and password if yes then give this combination username is admin and password:password or the username blank and password : admin.
second think is that if your isp provider give you a pppoe connection then you have to give the username and password which isp provider give you. try it
SOURCE: wrt54g wireless router
The default password of the linksys router is admin just leave the username blank, if admin did not work reset the router so it will be back to its default settings with default password admin and leave the username blank ..
Hope that helps........
SOURCE: trying to change the router settings to secure -
If the user name and password doesn't seem to work for you. Press and hold the red reset button on the back of the router for about 5 seconds. This will set it back to the factory defaults, were the blank user name and admin password will work for you. Once you accomplish that, you'll be able to setup your secure connection.
Good Luck,
and don't forget to leave a rating.
Thanks
Mark
SOURCE: I don't remember router user name or password, but
You can reset the LinkSys back to the factory default by :-
Powering the router and pressing the RESET button with a sharp object for 30 secs.
Open your browser and enter the URL IP configuration address
The default Login is admin and the PW is admin.
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE: If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Step 1:
Step 2:
Step 3:
Windows XP
Windows 7
Related Articles:
Step 1:
Step 2:
Step 3:
Windows XP
Windows 7
Related Articles:
