if the compressor is running you should feel it vibrating when you touch it if you have a amp clamp check draw should be at least 1 amp . You could check for voltage at compressor with volt meter should be 110 volts
Unlikely to be a capacitor but they aren't expensive to replace. More likely to be compressor failing to start, or controller faulty. Try powering up the compressor and fans to see if they run independently of the controller
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
i had the same problem. i ordered the circuit board as well as the red sensor. the problem was the sensor but because i had the unit apart i replaced both parts.
Shut off the airconditioner for half an hour and then try it on.
If you get the message, it can be that the fan motor or the compressor motor is not working.
Check to see if the capacitor of the fan or the compressor is bad and not letting it start up.
Sometimes if the fault has occurred while running then it can be voltage protection due to a surge.
This unit is designed with the intention of the fan running all the time. The compressor cycles on and off with demand, however the fan runs continuously to provide constant room circulation.
