Question about Razor Pocket Mod-bistro Retro Scooter
Why does my razor bistro wheels only turn when i pick it up off the ground
Razor ground force go cart
I don't think this would be a problem, as long as the wheels fit the axle properly, both in diameter, and length of shaft.
Aug 24, 2014 | Razor 300001-SL Ground Force Go Kart
How to fix a bodum bistro electric coffee grinder that doesn't grind well
This can be caused by several things;
If it used to be good but is now faulty it is most likely that it just needs cleaning. If you are using beans that are 'oily' they can clog the grinder, you should anyway disassemble it and clean every year. Do not use soap and water, just brush it with a stiff brush (e.g. the stiffest type of toothbrush) and a vacuum cleaner.
There is also a possibility that something has got into the grinder along with the coffee beans that has damaged the grinding wheels; in that case you need to replace the wheels.
Jul 29, 2014 | Bodum Bistro Electric Burr Grinder for...
Razor mx350
Have you tried removing plastic chain guard and making sure chain is not off track i had this problem and that is all it was.
Apr 24, 2014 | Razor MX350 DIRT ROCKET - BLUE
Razor Bistro replace back tire
get a rancher take pices out an make sure ur put it were the scurrs at an tire ur be rock an roll driveing
Jul 20, 2013 | Razor Bistro Cycle
Razor Bistro scooter won't take charge - light stays red
i had the same problem with mine and it ended up being that one of the batteries was bad, there are two 12v batteries wired in series under the seat, usually you can tell which one is bad by looking at them, one of the batteries will be swelled up
May 09, 2012 | Razor Pocket Mod-bistro Retro Scooter
The Battery takes a charge, but not enough to make it move. Do I need a new battery or something else?
Make sure the battery is full, if not, add distilled water to full mark. Clean the battery terminals and make sure they are tight. The folks at Auto-Zone will test the battery for free.
Apr 17, 2011 | Razor Pocket Mod-bistro Retro Scooter
Razor Ground Force Go Kart will not work.
replace thumb tab throttle. part is $12.99 from razor. go to razor site to order. i had the same problem after my daughter drove it over a bumpy sidewalk.
Mar 05, 2009 | Razor 300001-SL Ground Force Go Kart
Razor Pocket Mod-bistro Retro Scooter Logo
Top Razor Toys Experts
gbob59
Dennis Key
Dennis Key
Marvin
Marvin
Are you a Razor Toy Expert? Answer questions, earn points and help others
