The dryer won't heat. We already checked the power supply, the gas supply, and cleaned out the filter. The check filter light is still flashing as well
SOURCE: lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had the same problem. Redistributing the clothes inside the machine seems to do the trick. Even though the clothes seemed evenly distributed and I had far less than maximum capacity in the machine- it seemed to think that something was out of sync- simply moving the clothes around did the trick!
SOURCE: Washer wont drain displays OE. Pump makes a
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. If the issue returns then yes you should replace the pump, please check this repair manual on how to replace the pump. Please get back to me if you have any other questions.
Kevin
SOURCE: Lg dryer check filter light wont stop blinking and the dryer wont work
You may have a clogged vent line.
Which will cause the check filter light to go on sometimes.
If the air is not getting out the vent and is blocked the sensor thinks the filter is clogged.
And you will not get heat either.
Check that the flexible vent line behind the dryer is not kinked or crushed.
A simple way to check if the vent line leading out from the dryer to the out side of the house is clogged is to remove the vent line from the rear of the dryer.
If the dryer gets hot when the vent line is removed, then the clog is between there and the outside vent door.
sometimes the little door outside the house gets stuck closed due to lint build up.
Or anything can be in the vent going into wall too.
my dryer is gas.....that was not an available product choice
