Question about Cell Phones
What is a widget - Cell Phones
mikadot
  • Cell Phones Master
  • 2,113 Answers
In computing, a web widget is a software widget for the web. It's a small application with limited functionality that can be installed and executed within a web page by an end user. A widget has the role of a transient or auxiliary application, meaning that it just occupies a portion of a webpage and does something useful with information fetched from other websites and displayed in place. Other terms used to describe web widgets include: portlet, web part, gadget, badge, module, snippet and flake. Widgets are typically created in DHTML or Adobe Flash.
Widgets often take the form of on-screen device such as clocks, event countdowns, auction-tickers, stock market tickers, flight arrival information, daily weather etc..
Posted on Nov 30, 2013
Widget what does it mean
In Android, the word widget is a generic term for a bit of self-contained code that displays a program, or a piece of a program, that is also (usually) a shortcut to a larger application. We see them every day on web pages, on our computer desktop and on our smartphones, but we never give too much thought into how great they are. Widgets first appeared in Android in version 1.5, and really gained traction thanks to HTC's Sense-flavored version of the operating system. Prior to the release of the HTC Hero and our first taste of Sense, widgets were functional, but pretty bland in appearance. Since then, manufacturers and independent developers alike have done some marvelous things with widgets, and it's hard to imagine using Android without them. Android widgets come in all shapes and sizes and range from the utilitarian 1-by-1 shortcut style to full-page widgets that blow us away with the eye-candy. Both types are very useful, and it's pretty common to see a widget or two on the home screen of any Android phone. A full-page widget, like HTC's weather widget for late-model Android phones, tells you everything you need to know about the current conditions, and is also a quick gateway to the weather application where you can see things like forecasts and weather data for other cities. At the other end of the spectrum, the Google Reader 1x1 widget watches a folder in your Google Reader account and tells you how many unread items there are, and opens the full application when pressed. Both are very handy, and add a lot to the Android experience.
Most Android phones come with a handful of built-in widgets. Some manufacturer versions of Android offer more than others, but the basics like a clock, calendar, or bookmarks widget are usually well represented. This is just the tip of the iceberg though. A quick trip into the Android Market will dazzle you with the huge catalog of third-party widgets available, with something that suits almost every taste. With Ice Cream Sandwich supporting things like higher resolution screens and re-sizable widgets, it's going to be an exciting year seeing what developers can come up with.
Jul 04, 2014 | Samsung Star GT-S5233 Cell Phone
I have a Samsung Duos B7722 and I have a problem with a message that appears whenever I open pictures. The message is as follows: "Not Enough Resources. Close some applications and try again."...
it may solve through widget setting just remove some widgets from the widget tab on the screen 1 of ur duos phn and it can be done in the just go in display and light setting in the phone stteing menu thn widget n thn jus unmark the not reqired widget its like Setting>display and light>widget>unmark unnessary widget.....thts it hopefully it will work jus try......
Jul 29, 2011 | Cell Phones
HOW CAN I REMOVE WIDGET FROM MY SAMSUNG GT C6712 ON SCREEN
I think the Widget in the Home screen is in-built.
Just click the widgets button, you can see the bottom, available widgets appears... just drag and Drop widgets to keep in screen and remove from screen.
Jul 23, 2011 | Samsung B5722 Cell Phone
How can i hide the widgets on the screen? ,im using a samsung wave 525
hello mate,
!, Touch the widget on the top left corner of ur screen
2, den press de widget u want to move
3, den a yellow border appears arnd dat widget, den drag n drop it into the bottom widget box...
4, touch done on the screen..i thnk i helped u..:-)...
Jul 11, 2011 | Samsung Cell Phones
Lost my original clock how do i get it back
You can restore the clock using the same procedure as putting any widget on your phone.
Go to the screen where you want the clock and then do a "long press" on an empty portion of the screen. Basically hold your finger on the screen for 3-5 seconds until the widget menu appears.
- Tap Widgets (it may be under a separate menu like "Sense Widgets"
- Scroll to the widget that you want and tap to select it. If there are any customization options, they will come up now. Choose the options you want and then select Done. Your widget will now be on your screen.
You can move your widget by doing another long press on the widget and dragging it where you want it and then releasing.
Mar 06, 2011 | HTC Desire HD Cell Phone
I want to know about widget functions about password of widget
dear friend,
widgets are type of the shortcuts that enable you to access the important icons quickly.....you can select any widget from your widget settings...hope this information is fine
enjoy & cheers
Jan 08, 2011 | Samsung Star GT-S5233 Cell Phone
Please tell how can i run .widget file...
If you are referring to yahoo widgets first install the yahoo widget software
http://download.yimg.com/ycs/widgets/us/4.5.2x10a50/widgetsus.exe
after that you can use the .widget file by installing it onto the wigdget software.
please read here for more details.
http://widgets.yahoo.com/download/
Sep 20, 2010 | Computers & Internet
How do I remove and manage widgets from my home screen? Also, how do I delete the photos and music that is already on my phone?
To remove widgets from your screen, long hold the widget, and drag to the Remove button at the bottom of the screen.
To move a widget around, long hold and drag the widget to a different part of the screen. If you want to drag it to a different screen, use your track ball while long holding the widget.
To add a widget, press on the (+) button and the select HTC Widget or Android Widget.
To remove music and wallpapers (which are stored on your SD card), you first need to connect your phone to the computer via a USB cord. On your phone, go to your notifications screen (swipe down from the top of your screen). Select "Mount" and your computer will now recognize your phone as an external storage device.
The music files are in the Music directory, and the graphics are located in the Wallpapers directory.
Remember to Turn off USB Storage by going through the notification screen again.
Hope this helps and good luck.
Jan 13, 2010 | HTC Hero Smartphone
How do i close applications on the main page on a samsung jet mobile?
Basically to get rid of any reminiscent widgets (like if you were playing music and the widget still is in your desktop), just drag the widget you want to get rid off into the sidebar (the side bar will automatically expand when you drag the widget into it, and your widget will minimize and insert itself into the side bar).
Now the widget is officially closed .
Enjoy :) Ed
Sep 26, 2009 | Samsung Jet S8000 Cell Phone
Cell Phones Logo
118 people viewed this question
Top Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
