Bosch 23 in. SHU303 Built-in Dishwasher Logo
Posted on Nov 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a shu43co2uc bosch dishwasher that fails self test and displays CL on display. I believe this is a bad ntc sensor. the tub has water in it an inch or two and it does get hot but pump runs a few
Tryed to reset by shutting off breaker .canceling cycles . still will not wash . drain pumps a couple seconds and stops will not wash at all. does heat up water. steam when door is opened. water in tub hot . filters clean. any help would be great. tks
John
Level 3:
  • Master 794 Answers
  • Posted on Nov 30, 2013
 John
Master
Level 3:
Answers
794
Questions
Helped
290464
Points
3169
If the owner's manual does not give an explanation of the error code is, in the troubleshooting guide, you'll need a service / repair manual. Perhaps calling around to a few local appliance parts and repair shops- someone can clue you in on what the problem is and how to repair it.
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Feb 16, 2008
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Anonymous
  • 8619 Answers
  • Posted on Feb 13, 2009
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Anonymous
  • 39 Answers
  • Posted on Oct 29, 2009
SOURCE: Bosch dishwasher continues to run (Model SHX46A02UC)
searched oother sites. some report a circuit board problem where one of the solder joints overheated and burned out of contact. check yours and repair/replace if that is the problem.
if not at least you can rule it out.
Anonymous
  • 2605 Answers
  • Posted on Oct 31, 2010
SOURCE: I have a SHU43C05UC/22 Bosch Dishwasher. The
Welcome to FixYa.
Based on your description I'd say the issue is with the control...unfortunately.
The number"1" being displayed ( on models with the display like yours ) is actually an error code indicating a fault in the heating process.
Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described.
**B/S/H/ also issued a recall on certain models between 1999 - 2006 depending on the serial number so you may want to contact Bosch to inquire if yours is affected.**
http://microsites.boschappliances.com/safetyrecall/dishwasher/
or
Bosch dishwasher hot-line 1-800-856-9226
1-800-856-9226
Before calling, have the model and serial numbers on hand. A live operator can be reached at the hot-line 24/hrs day.
Those not affected by the recall still can be a problem but easily fixed. As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be calling in an authorized bosch service tech. if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Your control WILL differ in appearance, however the issue, the service and all the same info applies...except the part number. Yours will be # 431692**
**Flip this over and inspect the solder joints, it will be obvious when you see it...the cover for your models control comes apart in a similar manner**
This is where and what to look for, except I`ve re-soldered this one already...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed, other-times it will eventually stop or display "1".
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control ( # 431692 @ approx. $150 - $250USD...$167.99 at "searspartsdirect.com" ) and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Anonymous
  • Posted on Feb 04, 2011
SOURCE: When I press the start button, Bosch dishwasher
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
1helpful
2answers
Bosch dishwasher start with CL code
That is just saying the Child Lock (CL) has been activated.
Deactivate the child lock ' Bosch
Bosch Home https://www.bosch-home.com > ... > Get support
1. Press and hold the start button for three to five seconds ... When the child lock is activated, there will be a message "CL" in the display and all the washing ...
Bosch dishwasher child lock problem
Bosch-home.co.uk https://www.bosch-home.co.uk > ... > Dishwashers
Hold down the lock button for three to five seconds. You should hear an audible beep and/or see the symbol disappear. The child lock is now deactivated.
What does CL mean on a dishwasher? And how do I fix it?
Quora https://www.quora.com > What-does-CL-mean-on-a-dish...
This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ...
9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
How to turn off the CL on the display of a bosch dishwashe...
JustAnswer https://www.justanswer.com > Appliance Repair
Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone.
1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your
..https://www.youtube.com/watch?v=Xr4DBwACUW4
2helpful
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
5helpful
Have a shu 4322 dishwasher it fills with water and drains but the spray arms do not spray. have not tried anything yet.this dishwasher is not hooked up. it was given to me by a friend who replaced all his...
Welcome to FixYa.
There was indeed a recall involving the control replacement nearly two years ago now if I recall.
As for checking into the present issue ( it doesn`t sound like anything to do with the control based on your description ) it sounds like the pump impeller may have become stuck. Did the dishwasher sit idle or in storage unused for a period of time ?
I have a service bulletin I could send you via email regarding remedying that issue of stuck impeller if you contact me at [email protected]
I`d suggest you run the dishwasher through a diagnostic, but either procedure will require hooking it up.
To do this test/diagnostic on the SHU4322 series machine, it is as follows...
To start test program, press and hold both REGULAR WASH and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ "20" = version 0 without jumper).
When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone).
Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start button is pressed.
To start testing, press both the REGULAR WASH and RINSE & HOLD buttons a second time.
When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ "6" = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
2 = Heating fault
4 = Filling fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
i.e.
If water level switch has failed (opened), display will show fault code "4" and unit will continually fill and drain where testing won't be completed. If flow switch has failed (opened), display will show "0", water won't heat (to 150?F) and water won't stop circulating. If NTC probe has failed (opened), display will show fault code "8" immediately and testing will end shortly after water has started circulating.
What needs to be done to solve the problem will depend on the results/findings of the dianostic, so let me know what you find and we can go from there.
Either way keep me in the loop and I`ll assist you the best I can. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
1helpful
Fon the dishwasher
Hi, welcome to Fixya.
Based on the info you've provided, the dishwasher is indicating a error during the "fill" stage, hence the "F" being displayed on the Bosch machines.
Here's how to perform a test or diagnostic...
Make sure the power button is in the off position ( open & closing of the door will activate the "auto shut off" ).
Once certain it is "off" press and hold both the regular button and rinse & hold button, then turn the unit "on" while continuing to depress those 2 buttons. Initially, control module version # will display ( i.e. "20" = version "0" without jumper...not important for this ).
When the buttons are now released, the lights above them will flash. To start testing, press both the "regular wash" and "rinse & hold" a second time.
Let the test follow through, ( grab a coffee and observe, this will take a while )
When testing has ended, the display will show an error using codes as follows...
"0" = no error.
"1" = aqua sensor fault.
"2" = heating fault.
"4" = filling fault. and finally.
"8" = NTC ( temperature sensor ) fault.
The "F" code will not appear in test mode, only during wash. If you have a failed level switch for instance the test will display "4" and will continually fill and drain and test won't complete until you press the "on/off" button.
If the test complete's without and error or won't fill, replace the water valve. Original part Part # 425458 at "searspartsdirect.com", "apwagner.com" or #1105846 at "repairclinic.com" ( they use there own numbers ) or you can check locally by your model number & serial number.
Let me know if I can assist you further. Hope you found this helpful and if so please allow for a positive rating.
Thank you for choosing "fixya" and good luck.
macmarkus :)
2helpful
Hello. My Bosch dishwasher display letter F and do not start. What i can do? Gary.
Hello Gary, welcome to Fixya. Based on the info you've provided, the dishwasher is indicating a error during the "fill" stage, hence the "F" being displayed on the shu43 series machines. Here's how to perform a test or diagnostic. Make sure the power button is in the off position ( open & closing of the door will activate the "auto shut off" ). Once certain it is "off" press and hold both the regular button and rinse & hold button, then turn the unit "on" while continuing to depress those 2 buttons. Initially, control module version # will display ( i.e. "20" = version "0" without jumper...not important for this ). When the buttons are now released, the lights above them will flash. To start testing, press both the "regular wash" and "rinse & hold" a second time. Let the test follow through. Whentestimg has ended, the display will show an error using codes as follows. "0" = no error. "1" = aqua sensor fault. "2" = heating fault. "4" = filling fault. and finally, "8" = NTC ( temperature sensor ) fault. The "F" code will not appear in test mode, only during wash. If you have a failed level switch the test will display "4" and will continually fill and drain and test won't complete, until you press the "on/off" button. If the test complete's without and error or won't fill, replace the water valve. Part # 1105846 at "repairclinic.com" or you can check locally by your model number & serial number. Let me know if I can assist you further. Hope you found this helpful and if so please allow for a positive rating. Good luck. Macmarkus :)
Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on
by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press
ON/OFF button.
To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each
program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended
and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end
If more than one fault occurs, more than one light will be lit.
Let me know what you figure out. I can repair these boards most of the time.
1helpful
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
2helpful
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
together, (e.g./ “6” = faults 2 + 4).
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
3helpful
3answers
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
