Water starts to fill and then the solenoid fires but nothing happens. After 4 times of the solenoid firing the unit goes into drain cancel mode. have unplug dishwasher and reset but nothing. Have tried pressing high temp/ heat dry but nothing reset.
Here's a link for the repair manual for your dishwasher:
http://www.appliancerepair.net/kitchenaid-dishwasher-repair.html
Concentration should be on Chapter 2 subsection 2-3 "No Fill"
Then go to Chapter 6; subsections 6-2, 6-3, 6-3a, 6-3b, 6-3c, and 6-3h for testing procedures on relays, actuator valves, etc.
SOURCE: Kitchenaide KUDM24SE1 dishwasher will not fill with water
It may be the water inlet valve or the electronic control board. To check, remove the bottom toe panel. The valve will be on the left side. There will be live power, so use extreme CAUTION. Start the DW, 1. if you can hear the valve humming or the valve coil is getting warm, replace the valve. 2. Using a device with wires to check the power at plugs, connect to valve power connection, if power is present, replace valve else replace electronic control board.
SOURCE: Clean light flashing 7 times. Can't start the machine
The cleam light blinking means that the unit was not able to reach a proper heated wash cycle. Either your heating element failed orthe actual sump/pump motor system has failed. Check the element in the botton and see if it looks broken anywhere. If you can see a broken spot, you will k now that is the trouble.
Good Luck!
SOURCE: Kitchen aid dishwasher not draining....help
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
SOURCE: KitchenAid dishwasher KUDS01DJ does not
Please confirm your model is the same as the one shown in this manual.
i am unable to find any mention that "start pad" -- means door switch problem.
You can check out the door switch by getting to the right parts using this diagram. Door switch is item 12.
Please post a comment to confirm what you found.
SOURCE: I have a kitchenaid dishwasher
Dishwasher Problems - Waterwill not drain out
heatman101
