Emerson tv is hooked up to a cable box with an hdmi cable and is in the correct port. When set to hdmi1 it is fine but if any button is pressed on the cable box's remote, the tv goes back to "tv" input
SOURCE: TV does not recognize PS2 input
On the TV you should have a video, input or mode button. If you press that button while the PS2 is on it should pickup the signal. You need to be in video mode instead of cable mode since you are using the red, yellow, white cables. Many TVs have a few video modes so press it wait a few seconds and try again if it does not work. Hope this helps:)
SOURCE: Can't find the input/video channel for my Emerson TV
universal remotes are tricky, if you have the pamphlet, often times there are several codes for each brand. you have to try all the emerson codes for your universal even tho the power, volume and channel functions may work with several emerson codes, some of these specialized buttons (like input) may only work on your TV with one specific code.
also, if there are any unlabeled buttons on the universal try them with each new emerson code.
SOURCE: emerson tv with no remote will not go to aux channel
Need the remote to go to the aux. The number for parts and service is on the back
SOURCE: cant change channels or input using front panel/no remote
Buy a new remote,tries this website for an exact remote or very closse to the original.1-800-Factory Original.
SOURCE: lost remote control for an emerson tv. how do you
I just purchased one of these televisions and it didn't come with a remote. However, a Philips Universal Remote (SRU2103/27)
with a code 0520 works fine. I haven't explored all the codes but I can easily change from tv stations to Video 1 and Video 2 merely by pressing the "Input" button on the remote.
