Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Heater keeps trying to run 10 to 15 seconds smoking out the front then it will kick off the reset , i try it again an it does the same thing with it spraying fuel out the front, an i keep trying sometimes an then it will catch up an run, what could be the problem ? it is a ready heater R155 it fires off of spark plug
Posted by Gerald Smith on
1 Related Answer
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I have an older 50,000
The flame sensor is not working...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Dec 15, 2010
The furnace will only kick on after you shut the switch off for a few seconds.....
Shutting off the unit will reset the computer and erase the failure code. That is why it seems to be temporarily correct the problem. It seems that the unit is probably over heating. Because you said that it will run again after reseting the power. Try changing the filter and resetting the power.
Dec 13, 2010 | Goodman GMS90703BXA Heater
Red reset button keeps kicking out, i reset button and works fine for a day or two then kicks out again
The reset button kicks out because the thermostat detects overheating.
Anything over 150 degrees, the reset kicks out.
This is caused by 4 things.
1) Bad upper or lower thermostat. Thermostat sticking in 'on' position and elements overheating water.
2) Factory-installed insulation and cover are removed
3) Bad element shorted to ground at center of element, and element continues heating with 120V through the ground wire.
4) Loose wire near upper thermostat, that is shorting and causing heat.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Solution:
Check for missing insulation.
Check for loose and burned wires.
Replace both upper and lower thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If problems continue, test water heater elements and replace bad element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If you need more help, add a comment and I will respond.
Oct 29, 2010 | Reliance & 40 Gal Electric Mobile Home...
Pool heater comes on for about 15 seconds and then kicks off. A minute later it will do the same thing. Already replace hot surface ignitor probably because of over use. What ca the problem be?
I run into similar problem. Generally means filter is dirty. Run filter on RINSE or BACKWASH for a few seconds then try again. I am sure this is the cause.
Jun 28, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Dayton Salamander Heater - Blowing Unburnt Fuel/Smoke Randomly
I have seen this before, you need to replace the nozzle.
Feb 01, 2009 | Dayton (3E386) Heater
Sears forced air kero heater wont start, spitting fuel out front
sounds like the ignitor is bad, mine would try to light and do the same thing. I noticed one night that it was arcing out the entire length of the wires to the plug. If you have a good spark then i would suggest a CAD flame sensor, very cheap.
Jan 22, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Menu keeps popping up
Hi, heres your fix, replace all of the front control board tact switches, part number is 23344443 & have a Merry Christmas, BMW Rider
Aug 24, 2007 | Toshiba 32A43 32" TV
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
192 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
