Samsung NP365E5C 15.6"" LED Notebook - AMD A-Series 2.50GHz Logo
Posted on Nov 29, 2013
Samsung reset password I did a factory reset on a samsung NP365E5C. Win 8. Now the password hint is reset password. I have tried to do that w/o any luck. Help?
Win 8 reset to factory. Now password hint is reset password. I have tried. Help?
2 Related Answers
Anonymous
  • 1511 Answers
  • Posted on Sep 03, 2009
SOURCE: i need factory reset for samsung propel
Remove the SIM card and turn on the phone.
Enter *2767*3855# or *2767*2878#
Hopefully, one will work.
Regards,
Waqar.
Note: All data will be lost in this MASTER RESET.
mobil master
Computer Repairing
  • 14641 Answers
  • Posted on Aug 02, 2012
SOURCE: reset password on Samsung a797
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
How do I reset my Samsung netbook to factory settings .It now is reverting changes after failure to configure window updates
Before you do that, try google for "win 8 windows update fixit" Run the fix from Microsoft. It should work.
tip
I Forgot my Samsung Password - How to Reset Samsung Password
Most of our Samsung PC, laptop or notebook users often meet problem with Samsung password reset. Sure, easy to forgot password while troublesome to find ways to unlock Samsung password. Then I will share some methods for Samsung password recovery.
Method1: The most saving time and efficient way to reset Samsung password
Opt for professional Ainorsoft Windows Password Recovery software to recover our lost Samsung password. Now, we can login our PC within minutes and without losing our important data. The software does not require what version of Windows you are running or whether you have any technique computer skills. The followings are easy steps to unlock Samsung password.
Step1. Download the program from an accessible PC;
Step2. Burn the .iso file to a blank CD/DVD or USB Flash Drive;
Step3. Break forgotten Windows password with the burned CD/DVD.
Method2: Logon Samsung laptop from other accounts with administrator privilege
Such as Windows XP, Vista, there is a backdoor or default administrator accounts. If the account is accessible, we can refer to it to help us reset the forgotten Samsung password. Also, we can access PC with other accounts which own administrator rights, you can use them to login your PC and reset the lost password. Let's take Samsung Win 7 Laptop as example:
1. Logon Samsung Windows 7 laptop from the accessible account with administrator rights.
2. Start - Local Users and Groups - lusrmgr.msc in the Search box - ENTER.
3. Local Users and Groups - choose Users.
4. Right click the account needed to reset password, and then select Set Password.
5. Input and confirm the new password.
Method3: Samsung password reset with Ophcrack or Offline NT Password & Registry Editor
Ophcrack is free tool based on rainbow tables. It can recover alphanumeric passwords in seconds while not 100% work. We need download its free ISO image, burn it to a CD and boot from the CD. When program starts, we locate the locked user accounts, and proceed to recover the passwords.
Offline NT Password & Registry Editor can erase the Windows password by burning its .iso file to a CD.
Method4: Samsung password recovery with password reset USB or CD/DVD
The last method may not help us if we do not have it before we lost the password. But the password reset disk is important for us Samsung PC users. We should create the Samsung password reset disk once we set password for our PC. Take Samsung Windows XP as example to create a disk:
a. Start - Control Panel - User Accounts - account name locked.
b. Under Related Tasks, click Prevent a forgotten password.
c. Create a password reset disk by following the Forgotten Password Wizard.
Bypass Samsung password with the created password reset disk:
d. Click the username when we get to the Windows logon screen and then press Enter when password box appears.
e. Click use your password reset disk. The Password Reset Wizard starts and Next.
f. Insert the password reset disk, and then Next.
g. Type a new password in the Type a new password box and in the confirm box.
In the Type a new password hint box, we can type a hint to remind us the password if we forget the new password if we want to use one.
h. Click Next, and then Finish.
With the above four methods, we will be ease to reset Samsung password if we forgot Samsung password. And we also welcome the all readers share them with your friends. It will be helpful for them to unlock Samsung password instantly!
on Mar 10, 2011 • Computers & Internet
4helpful
4answers
I have forgotten Windows 8 password on Samsung Smart PC. How should I do to reset Windows 8 password? I'm in hurry to access Samsung Smart PC.
Samsung Smart PC, also called Samsung 700t, is installed with Windows 8 operational system.
  • 1. If you have created PIN code for Windows 8 logon, when the Windows system prompts you that your login password, you can change to select login Windows 8 with PIN code. It is the easiest way.
  • 2. If you don't have PIN code and another administrator account, you can think about third-party password recovery software. Here, I recommend you Windows Password Genius. And this is a software you just need USB device and accessible computer. I just learned from here Get access to Samsung 700t after Windows 8 password forgotten .
I HAVE A NEW SAMSUNG LABTOP WITH WINDOWS 8 I WANT TO CHANGE 8 TO7 HOW CAN I DO THAT
The windows seven discs are available to download from the Microsoft website.
11helpful
3answers
1helpful
HELP PLEASE
by resetting to factory settings, the security password is also reset.
Try this code: 00000000 (that's 8 zero's)
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
