Dacor ECS127 Epicure Electric Single Oven Logo
Question about Dacor ECS127 Epicure Electric Single Oven
The code u20 is illuminated and oven doesn't work. What dies it mean and how do I fix it
Posted by Nan Feldman on
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 • Ovens
2answers
What does F7 meanon my ge oven
The F7 error code means that a button on the touch pad is bad,you can clear the error code by the pushing clear/cancel button if it doesn't reoccur all is well. If it returns (what i have heard from my customers is that it always reoccurs in the middle of the night when their fast asleep) the touch will need to be replaced
I hope this helps ,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 • GE Ovens
8helpful
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 • Amana Ovens
5helpful
My whirlpool oven has come up with code f 02 and wont work
Hello, the F02 error code on your oven means oven temperature sensor shorted and it can only be fixed by replacing the oven temperature sensor.
Thanks
Oven panel all lit up but won't work
control is the oven clock . look for a code in the display . if no code . unplug or turn power of 5 min and retry. may need a colck .. mm
2answers
What does F4 mean, oven shuts off and code comes up?
The code indicates an Open or shorted oven temperature sensor. Solution is replace oven temperature sensor Here's a link to a short tutorial on how to make the repair... http://www.applianceaid.com/changingoventempsensor.html
3helpful
3answers
Error code E6 F2
We repair these control boards frequently. The E6 F2 error is very common for whirlpool ovens and almost always is caused by the control board. It can be repaired quickly and reliably. www.fixyourboard.com
Jul 07, 2009 • Ovens
2answers
Ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
Oven error code
See my solution to OVENMAN/April 12, 2007. I have supplied my fix to over 650 individuals and have had a high reported success rate.
Top Dacor Ovens Experts
Jaime Hernandez
Paul Bade
Ngoro
Are you a Dacor Oven Expert? Answer questions, earn points and help others
