Ford focus travelpilot fx unit fader does not work. rear speakers stopped working & turning fader from f to r has no effect. tried full system and audio resets to no avail. help!
Open the fuse panel and remove each fuse while the radio is playing. The ignition key is in "ACC on" to ascertain which fuse connects to the T_Pilot. Make a note when you've identified which fuse is the T-Pilot's circuit. Replace each to original position after 30 seconds. By removing the fuse, you disconnected all power to the Travel Pilot. When you replaced the fuse, there will be a delay as the Travel Pilot reboots itself, maybe 2 to 5 minutes. If its fully functional again, then it was a software glitch Ford deliberately programmed to psyche you into trading-in your old Ford and upgrading to a newer model.
SOURCE: 2000 ford focus rear driving lights
Had this problem myself. Try replacing your brake light switch, they are not real expensive and can be changed in a matter of mineuts. It is located by following your brake pedal all the way up to the top, when you get there , there id a switch that when you push down on the brake it releases the button to put you brake lights on and when you take your foot off the brake itallows the switch to go back.
SOURCE: hello, i have a ford focus
Well, if you have access to a multimeter, you can unhook the switch and check resistance across it or you can leave it in the system and verify voltage is making it to the pump. This will tell you if it is the switch or the pump. The other option is to guess and replace one of them and hope you are right. If the rear screenwash is powered through the same button, then the problem is definately the pump. There may also be a relay in the system, which could also be the culprit. Your best bet is to find a wiring diagram (check out the Haynes manual from your local auto parts store) and see what is in the circuit, then trace voltage to the first component that no longer has voltage, and there is your problem. Remember, no voltage will pass the switch unless it is closed.
SOURCE: rear speakers stopped working
my speakers went out front and rear i was told by an audio tech. that the systems that chevrolet put in them each speaker has its own amp to bust the sound the only way to fix it is to replace them.
if you have a warranty chevrolet will replace them otherwise find a junk yard or new system. i ordered a set of used speakers off ebay havent installed yet.
SOURCE: Brake light, Turn signal not working rear right 06' Focus
I have a 2000 ford focus no brake lights. with the brake lights the transmission would not go into drive .replaced the brake light switch checked fuse replaced turn signal switch with no results then i moved onto the wiper switch and replaced it as much to my supp rise it fixed the problems
SOURCE: ford focus - rear washer not working...
you can change this by removing the 4 screws holding the trunk cover and pull until the clips pop out and you can change your motor
