Hi Bruce Lisanti,
My name is Rohan and I work for Dell.
Since you have already replaced the paper tray and fuser, going by the symptoms that you have mentioned, seems to be like an issue with the Feeder assembly. If the printer is in warranty, please call the dell tech support in your country to receive support. If it is not under warranty, we request you to take it to a local technician.
-Rohan
Social Media and Community Professional
Order Status: http://dell.to/1fgKSTr
Download Drivers : http://dell.to/1hcxG98
It sounds like the fuser is not heating up to the correct temperature. If you are printing on specific papers, for example: envelopes, bond, linen, make sure to set your printer settings accordingly. Otherwise you will need a new fuser unit for the printer.
Obtain an IP address from the IP name of your site (your site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
Open an IP socket connection to that IP address.
Write an HTTP data stream through that socket.
Receive an HTTP data stream back from your Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
the label with the adhesive on the back when it go through the heating unit it goint melt will coming off and stick on paper path it cause paper jam, sugest print label use inkjet printer.
Apparently others have tried to obtain a service manual for that model, and one was not available. Frustration was expressed, but it did not result in obtaining a service manual for that model.
Here is another approach to try for repairing it. Perhaps a service manual for a similar model, since your is from 2013, would be helpful. Since the link above from Dell shows other model numbers using a similar part replacement so maybe service manual for one of them could be located: 2130cn 2135cn 2150cn 2150cdn 2155cn 2155cdn
Most router (DHCP servicer) issue an IP to any device on the network, is your PC on the the same subset of the network? Can you ping the printer? Check your printer and device property, make sure you have the same IP address and you're on the same subset.
Incorrect, the part number is 330-0711. It is the same one for Dell 1320cn / 2130cn / 2135cn/ 2150cn / 2150cdn / 2155cn / 2155cdn. $99 directly from Dell.
